Topic: v.1.2b3 distributive (Windows 7/8, MAC OS)
Beta distributive for Windows 7/8, MAC OS (64 bit)
New:
- No staff in a330 menu
- GroundService plugin should work with GPU, DOORS, FUEL well
- try another version of push-pull mouse for mac (need to check it when you in 3D Cockpit lock - see screenshot)
http://jardesign.org/forum/img/m/22/t/p19rt6lpuf1u915ll1crk21o1o6u3.png
If you have not push-pull work on MAC, please report this with OS version info (Maverick, Lion, etc)
Please install it as clear installation, not mix files with other version, but sure, install NavData update if need.
Download link http://jardesign.org/a330/download/inst … _1.2b3.zip
  - be sure, that you use X-Plane 10.35 or later
  - copy unzipped «GndServices» folder to ../X-PLANE 10/Resources/plugins/
Thank you!!!!
Add Aug, 06:
fix 1 for this beta:
ok, if you are on MAC and push-pull not work for you, please try this mac.xpl
(need delete old from .../X-PLANE 10/Aircraft/330.../plugins/330/ and put new there).
Re: v.1.2b3 distributive (Windows 7/8, MAC OS)
I tried already - positive: still no CTD so far.
System
- MacOS Yosemite 10.10.4
- X-Plane 10.40b6
- Magic Mouse
Push/Pull working at first start. Then I replaced my _pref file and started X-Plane again, push/pull stopped working.
Maybe related to the prefs?
Cheers,
Tim
Tim
don't think so... like a mystic
Just had a CTD:
System:
Mac OS X Yosemite 10.10.4
Magic Mouse
Skymaxx Pro, XSquawkbox, NOAA Weather Plugin
Had just pushed back, started engines, turned off APU, turned off apu bleed, switch from ignition to normal, the the CTD occurred.
rsd99 wrote:
Just had a CTD:
System:
Magic Mouse
thanks for log! What about push-pull on your mac?
rsd99 wrote:
Just had a CTD:
System:
Magic Mouse
push/pull seems to work.
7 (edited by captbullett 2015-08-04 22:46:57)
On this report ;
1) OSX 10.10.4 Yosemite
2) XP 10.40B6
3) iMac Blue Tooth mouse ; called "Apple Magic Mouse"
4) Apple Wireless Key Board
    At first set-up and a quick-start because this is all it takes to test to see if the "Push-pull" works, I tested the Push-pull on the knobs on the AP and yes it now does work on the initial test.
Now, I will further test and see what the capability of the push pull is.
Thank-you JAR , and thank-you everyone else for the good work on the posts they look very good now and I am sure JAR likes the format.
P.S. I find the action of the new Push-pull very smooth it does take a little getting use to but it works well ...
OSX Yosemite, X-Plane 10.40B6, Apple Trackpad and Wireless Keyboard:
Mouse well scrolling (two fingers up and down) works
Push (one finger tip) and pull (two finger tipp) does not work
I start wondering if it's my fault and if I just don't get it right. If I had a conventional mouse, push and pull would be left click and right click, correct? So on my trackpad it should be one finger tip and two finger tip. But that does not result in anything, sorry...
Alex
9 (edited by flydav 2015-08-05 00:27:17)
Ground service does not show up in the menu of b3, b2 was fine
Edit: Sorry I see that the menu has now changed and the staff vehicles are now relocated.
10 (edited by pic 2015-08-05 04:26:53)
Howdy,
Lost all systems (and checklist) after programming flight plan. I was turning on emergency exit lights, controllights  before my taxi to runway. When I looked down, everything was blank on the whole console...pdf, including the fmc and checklist. Everything else worked like a charm, inc the mouse control.  Here are my specs and logs;
Windows 7 pro 64 bit
x-plane 10.40b6
Thanks for a great job on this ac!
OK, in addition to my previous post.....tried it with xplane 1036 on Windows 7pro 64 bit and basically the same happened, (pdf, including the fmc and checklist disappear) except:
Was able to get ac in the air, but when intercom from passenger cabin announced  all is ok in the cabin everything again went blank. However, I used air fmc and AirTrack to follow the flight path to a near successful landing (missed the center line by 30meters/100ft).
Again, attachments below
On this report ;
2) XP 10.40B6
Did you try restarting? Thats when my push/pull stopped working. Did you import your old .pref file?
Cheers,
Tim
13 (edited by captbullett 2015-08-05 10:51:15)
Did not get that far the was a birth in the family last night and uncle B. had no sleep ... Will try now ...
meistersoda wrote:
On this report ;
2) XP 10.40B6
Cheers,
Tim
All the best to the newborn!
Thats strange. For me it stopped working after restart. I copied flightplans, liveries, navdata and the a330_prefs.txt from the old plane. Prefs to get my quicklooks back. I will try to re-replace it with the beta file. Maybe it makes some difference.
Tim
I just tried the Push pull after re-starting XP and it works just fine I did not have to do anything there are somethings that do have to be put back like the fuel truck and such since, I do see a second file I do not see instructions on what to do with it ... but everything else works.
meistersoda wrote:
On this report ;
2) XP 10.40B6
Cheers,
Tim
I was wrong I just stopped working now 20 min. in to the flight, KLAX/KATL this was strange ...
Tim
Cheers,
Tim
Just had another CTD
System:
MacPro OS X 10.10.4
17-4770k, 16 GB RAM, Nvidia GTX 970 4GB
X-Plane 10.36r1
Magic Mouse
Saitek X-55
synopsis:
    was about 80 miles form T/C, not touching anything, just looking out of the window, and got a CTD.  push/pull was working during this flight.
question:
   are things more stable if i move it out of the "Heavy Metal" directory and put it in the base "Aircraft" Directory"
In all MacOS CTD files - including mine, although its stable atm - those lines are characteristic
8    mac.xpl                           0x00000000a9c9e44b lua_pcall + 203
9    mac.xpl                           0x00000000a9c4a26f xa::Avionics::draw(int) + 287
10  mac.xpl                           0x00000000a9c59def sasl_draw_panel + 127
11  mac.xpl                           0x00000000a9c220ad drawGauges(int, int, void*) + 157
so it seems SASL related. Is there anything special in the context of this prodecure call?
Cheers
Tim
18 (edited by captbullett 2015-08-05 14:49:03)
thanks Sasl has been an on going issue but I have not seen this, you must have puled from DRef's Which I haven't done I usually pull from CTD thank you it's much easer to read.
Cheers
Tim
Its from the window you get right after CTD. Its informative I think. If you need or want some help on debugging please let me know. In real-life I am a software-engineer so maybe I can run some tests for you.
Cheers
Tim
Cheers
Tim
thanks for report! what flight situation was at that moment?
21 (edited by Anterialis 2015-08-05 16:18:36)
(I dont mean to interrupt the ongoing conversation)
iMac 27 later -13, El Capitan, xPlane 10.40b7.
No CTDs so far, done 3 flights. Restarted XP several times, haven't restarted computer. I do however have a problem with the NAV mode, it is stuck in HDG and won't change to NAV hmm I am doing the same things with this third beta as I have done with all the other 330s. Right after take off, the AP follows RWY heading, and won't follow my SID / flight path as selected on the MCDU. I feel I'm doing something wrong, any suggestions?
Hmm.. But how can you flight if your push-pull not work?
23 (edited by Anterialis 2015-08-05 17:10:53)
I forgot to mention that hmm push and pull works well! with the third beta! It did not work yesterday with the customized config file, but now it does smile
For the first time in two months or so ... no CTD. I was flying the v1.2b3 (from yesterday) KSLC34R - KLAS25R, FL320 and CI 20.
Push and Pull work OK; Rotate is a nuisance. It's very hard to dial in an altitude or a heading. You keep under- and overshooting the desired value in the MCP. The mouse wheel is a royal pain in the $ss. Is there a way to get the 'old' manipulator back?
Ah! OOOOk!
