I'm going back to the stable version let me know when and if you want my help instead of people just running off, and not giving any good information in order, I see here is wa, wa, wa instead of !, 2, 3, so the information can be put into some sort of order ! and make sense out of it. this is what the developers need ...
Example what a report should look like when working on an issue;
1) I am running on an iMac 27"
2) I am using a blue tooth mouse and keyboard
3) I am using X, Y and X
and these are the results:
the new trackpad does not work well with the A330 and need to be looked at because I cannot turn the knobs.(this is just an example and not a real issue)
and this is what a report should look like so it is short and sweet and is in the same format every time so anyone can read and determine if they are having the same issue as you are. and work on the issues together.
lets be professional when we are posting on this website please.
