Topic: v.1.2b2 distributive (Windows 7/8, MAC OS)
Beta distributive for Windows 7/8, MAC OS (64 bit)
Please install it as clear installation, not mix files with other version, but sure, install NavData update if need.
Download link http://jardesign.org/a330/download/inst … _1.2b2.zip
  - be sure, that you use X-Plane 10.35 or later
  - copy unzipped «GndServices» folder to ../X-PLANE 10/Resources/plugins/
some info about..
1. This week we complete some FCU rework. Bare, Spd, Hdg, Alt and VS push-pull managed by mouse like
Left Mouse = Push
Rght Mouse = Pull
Mouse Wheel = Rotate
I think this useful.. but need test by you, sure.
2. We include new Ground Service plugin to 330 pack as "separate-installed" plugin (to Resource/Plugins/ folder). It have extended Cars set and cool customizable, have a path editor, you can build and add own cars and some other features. Sure, it work with 330 as default, but (i think) more interesting compare prev "build in aircraft" plugin version.
Also this plugin will have a special option - For users who want build own Ground Service sets and use it with any of your aircrafts too, will be possible to make payware registration. After this registration, plugin will work with any aircraft.
This time we not cut "old" ground staff from plugin and you can find it at menu. Next versions it will be cut and you should use a new Big Ground Service plugin.This time you need use old plugin to call GPU, FUEL etc. New plugin is for first look!
No tutorials now, sorry. May be later.. but this may help
https://youtu.be/T8S04FQgdNY
http://youtu.be/TnKK_zIyuFY
3. As you know may be, the new SASL version is released. I don't know is it good or not - will see, will test.
Thank you!!!!
A Looot!!!!!!!
http://jardesign.org/forum/img/m/22/t/p19rlluvu7bn41c0ko0tneu9eu3.jpg
Re: v.1.2b2 distributive (Windows 7/8, MAC OS)
sounds nice! mouse wheel support is most certainly welcome, but please fix the issue with STAR altitude constrains ignored by the VNAV part of the FMC, it is seriously bugging me...
If you need any Beta testing on Mac I have the time.
your friend,
Coming soon! Before post it - some info about..
Left Mouse = Push
Rght Mouse = Pull
2. We plan to include new Ground Service plugin to 330 pack as "separate-installed" plugin (to Resource/Plugins/ folder). It have extended Cars set and cool customizable, have a path editor, you can build and add own cars and some other features. Sure, it work with 330 as default, but (i think) more interesting compare prev "build in aircraft" plugin version.
I hope Slava make and post some screenshots soon..
3. As you know may be, the new SASL version in near release. I don't know is it good or not - will see, will test.
Super news!
Good news!
Did SASL developers announce improvements for mac? I still get CTDs while taxiing or takeoff - at least with Gizmo&SkyMaxx Pro. Still suspecting them and SASL to cause the errors...
6 (edited by FS Steven 2015-07-31 09:47:38)
Not that much time for beta testing since I have to prepare myself for a math test, in order to get accepted for a premaster course for Aerospace Engineering. However, I never learn non-stop continuously, so there will be some time to test it!
Good news, looking forward! smile
meistersoda wrote:
Good news!
I hope yes, but think.. no... sad need test
good luck on your test ...
Thank you captbullett! That's appreciated! When I am finnished with MSc Aerospace Engineering, I hope I can apply for Airbus. Then becoming supporting staff for JARDesign, haha! tongue
uploaded
long time  no here from you I know you are busy how are you ...
uploaded
uploaded
Hi, capitan! Just have a lot of job at real airport and work on some a330 improvements and also on traffic (but not much). Sure, by newborn baby eat a lot of time, but thats cool life! smile
Damaged archiv in 1.2b2.zip, please reupload
14 (edited by captbullett 2015-08-01 23:50:18)
I have the same issue. iMac the things that are missing is the mouse I can't make any adjustments no push no pull ...
thank-you
upload is still not complete - too slow server
16 (edited by captbullett 2015-08-01 23:57:08)
Good Day,
K, thank-you the new sound of the engines is very good ... can't wait to get into the air
P.S.I might run out of key because I will have to re-download this version. Sasl load looked good on mac.
done now, sorry for delay!
thank-you
19 (edited by Anterialis 2015-08-02 08:38:04)
Deleted custom sounds. Done one flight, no problems. Second flight, bug with MCDU, but I believe this is a known issue with the pseudo points: Set up FP, then did a couple "direct to". Navigation Display is showing correctly the flight path, but autopilot doesn't follow it, I believe it wants to go to "cross" pseudo point. I also missed TOD pseudo point. So know (during this flight) I have to use manual heading as lateral nav.
Is this bug known? Any plans on changing the usage of pseudo points (if this is the reason for my problem)?
Thanks in advance for a the great work! No CTD so far. iMac on El Capitan beta, x-plane v10.40b6.
https://dl.dropboxusercontent.com/u/5276966/MCDU.png
https://dl.dropboxusercontent.com/u/5276966/ND.png
EDIT:
Im sure I have read this somewhere, but I can't seem to find it. Ive tried searching, but since I have to wait 30s between each search, I can't really try that many searches. Its regarding these blue and red lines around edges inside the cockpit and in the horizon marking mountains etc. How to remove these? Could anyone point me in the right directions as to where this is reported?
https://dl.dropboxusercontent.com/u/5276966/lines.png
Seems I am not able to turn the knobs with my iMac trackpad. For Apple users, it might be useful to disable this feature and to give them the chance to use the knobs like before (or maybe I am just too stupid to find out how to...)
Alex
21 (edited by billchenmulgrave 2015-08-02 09:20:31)
Oh and something else for our beloved Romanov to work on in the future, add the ability to draw radials and circles from a fix! http://i1375.photobucket.com/albums/ag444/thedude39/3_zpsebce919c.jpg
Downloading now. Will try a quick flight from LFMN-LEBL and test the new plugin and wheel clicks/turns, et al. DL done in a flash! installing now...
23 (edited by thomas_99 2015-08-03 05:25:44)
CTD: Plane Crashed...
I just started engines and pressed the "<-" key to move the position more left....
best regards...
I bought this plane 3 days ago. I just installed this beta and already completed 2 short flights (LIRF-LICC and back). Had no issue.
New FCU (push/pull and rotate) management is a great addition and worked like a charm here. Thank you!
New Ground Service is too cool, but I noticed that if I call refuel truck using the new plugin the refuel panel doesn't show up. Other than this, it's great!
CTD just after take off and after switching on A/P. Bummer ...
Attachment icon X-Plane_2015-08-02-154341_iMacIVYBridge.crash.zip 16.64 kb, 255 downloads since 2015-08-02
