Re: [STABLE] v1.1r1 (Windows 7/8) posted
jusku wrote:
flavio58 wrote:
Full flight tested and fully functional. I am really happy. Many thanks to JAR and BSS Simulations for the great work done.
BSS Simulations?!
Yes, the beautiful custom sound pack of Blue Sky Star Simulations for Jar A332
https://www.facebook.com/BlueSkyStarSimulations
27 (edited by emha 2015-06-10 15:57:05)
A new try, now with the v1.1r1
VATISM Flight EDDM-EDDF.
All looks great. And at the T/D, we need more drag, spoiler ... CTD.
good day,
thank's for the link ...
flavio58 wrote:
jusku wrote:
BSS Simulations?!
good day,
thank's for the link ... when investigating the BSS sound there are questions and until i see a better way to download and up-date the plugin I have to stay with JAR sound.
flavio58 wrote:
jusku wrote:
BSS Simulations?!
30
Folks
I am now able to successfully fly this excellent airplane without any CTD.
Using latest release 1.1r1, X-Plane 10, via steam (latest release ), using BSS sound and FMC plug in, I have now flown 3 flights with no CTD.
I reboot my computer each time (running Yosemite 10.3.3), go straight into X-Plane, select the airport I would like to start from loading the Cessna, I select a gate, then load the A330, cold and dark and all is good......never a hiccup.
Hope this helps.
SNK
31 (edited by arnelh 2015-06-11 15:20:24)
hello !
no CTD´s now, but  I have some other problem
Nothing found on the BUGLIST,a little bit confused about the versions (something about cutted waypoints or missed waypoints) but I have none at all APPR´available at specific airports e.g LYTV (A320neo have one, RWY 32, e.g)!
see @screenshot!
I use default, Aerosoft NAVDATA Pro, and NAVIGRAPH Navdata (all new) without success !
sorry if already reported, as I said a found nothing about missing arrival routes and approaches !
http://jardesign.org/forum/img/m/537/t/p19nhh8tan1glir971t281invg0t3.jpg
Hi everyone.
I tried to install this new version, but the activation window didn't show up. I first removed the old version out of the heavy metal folder, the updated xplane to .36 and placed the plane in the folder. I was able to open the plane, but was not promped by the activation windows. Opening a default plane first, the changing to the A330 didn't do the trick. A reboot didn't either. So I re downloaded, again no luck. The old version works great. I don't know what else to do.
Running windows 8.1
sounds like you need to up date a service Pack or, a VBC++ up date ... do you have you auto-up-date on.
jusku wrote:
Hi everyone.
Running windows 8.1
V1.1r1 does not work good with airfmc (Win7-64, xplane) . Some texts are missing. Latest Version of AirFMC + Plugin installed. IPad Air 2 used.
Please see pictures:
http://jardesign.org/forum/img/m/552/t/p19nk7704g1bqd1gdl7uv18f58oc3.png - http://jardesign.org/forum/img/m/552/t/p19nk77tf113d81fmj10vmva79vng.png
http://jardesign.org/forum/img/m/552/t/p19nk78gel168lk691tpu5661t4vp.png - http://jardesign.org/forum/img/m/552/t/p19nk798n7e4k7v24093q01mq616.png
11 hour flight from Paris (LFPO) to Reunion Island (FMEE). Everything perfect, no CTD. Just incoherent landing weight indicated.
Took off at 223 tons with 76 tons of fuel, and the landing weight was predicted at 200 tons, which obviously was overweight.
The actual landing was 163 tons. Just a bug that can be easily ignored, but a fix would be nice smile
36
Fresh version of a330 send to AirFMC all needed data and it is "AirFMC ready". I think AirFMC need to be updated to be possible to show all correct. Its author work on it, as I know. Not need any changes from JARDesign side.
37
No crashes on my flight from KCLT to KMIA.  Mac OS 10.10.4 XP 10.4b2
38 (edited by TDPlane 2015-06-13 17:40:13)
Against all odds ... a new try ... with X-Plane 10.36 !
Flight from KDTW to KBNA. Smooth sailing all the way down to the descent. At about FL130, X-Plane crashed to desktop when I pulled out the speed brakes.
Bummer! I really love this fine piece of work! One of my favorite aircraft. Please please fix it ...
Attachment icon X-Plane_2015-06-13-193144_iMacIVYBridge.crash.zip 16.67 kb, 338 downloads since 2015-06-13
Attachment icon X-Plane_2015-06-13-193144_iMacIVYBridge.crash.zip 16.67 kb, 352 downloads since 2015-06-13
We have beta 10.40 with "lua memory locker". When next a330 beta will come, we have a chance to get solution.
40 (edited by captbullett 2015-06-15 12:26:46)
yes, I up-dated the XP to 10.40b2 and i am using A330 V1.1R1 right now it looks very nice there are some new thing in the setting to work with.
P.S. this version has Video again in 64 bit so, for customer support it will be good ...
41
CTD after StartUp, pushing the Auto Brake max button.
MacOs  10.10.3, X-Plane 10.40b2, 332 Version 1.1R1
I ran a EDDL to EGLL just last night also, and using the 10.40b2 , yes the first try I did have a CTD but I over looked it and after that I had a very good flight I will be working on Flight 2 today ... usually it is the third flight after downloading a new copy of the aircraft and it does not matter which aircraft you are using that I have a CTD, so you might keep a look out for this ...
Hi guys, i`m in cockpit now )))
What is the latest version of A330 at this moment?
44 (edited by captbullett 2015-06-17 12:13:51)
good day,
stable V1.1r1 and 2.4B
hope this helps and 10.40b2 is out for XP some aircraft might not work so check first but i am running A330 V1.1r1 and is ok so far but I haven't gotten to flight 3 it usually has a CTD then so I hope it has resolve the issue with this issue of XP.
Nevertheless, I also noticed that there are some other fixes that everyone will be very happy to see yet I do not want to be telling everyone to switch yet, until the developers have time to get the aircraft ready to up-date for the 10.40 XP...
45 (edited by Luke173 2015-06-17 15:45:03)
Had my first flight with this revision without CTD.
OS X 10.9.5, XP 10.40b2
big_smile
(Had some problems with Autoland though)
Attachment icon bbox_log.txt 143 b, 346 downloads since 2015-06-17
captbullett, thx to you captain. Now have activated version of A330-V1-1r1 and go ahead.
I`m lost my researches in A330 on 1.5 month due work travel, and now try to be in game like an good old times, when we work on first Alphas.
CTO on ramp
https://www.dropbox.com/sh/qle7olkjc1hw … rdtsa?dl=0
48
glad to help out...
49
Well, I talked to haversine support and got a new plugin for AirFMC, but not all problems are solved with the new plugin. They said that there is also a bug in the current v1.1r1 release and the A330 needs an update...
best regards, Thomas
50 (edited by captbullett 2015-06-18 13:53:33)
I have used this aircraft with Navigraph data and found it to be very reliable I also use the Cloud charts that go with the data and I can pick out the SIS's and STAR's that I want to use with very good routes and no issues.
Since, I up-dated the X-Plane to version 10.40b2 any issues I did have with the A330 and non-issues so maybe if you can give some details on the issues you are having i might be able to help you out and get the aircraft up and flying the way it should and also JAR watches the posts so he can keep an eye on the issue and help if needed...
P.S. The pictures you are showing does not give me any information I can use I need the route info and SID and STAR used in the planning so i can fly the route to see if it is in the UFMC or something else... but i do not think it is the UFMC since, I have had many good flights.
