Topic: SOLVED: How Do I Edit the LR A330 Set? Won't let me edit, overwrites.
I just purchased GHD and setting up my aircraft. The LR A330-300 appears to be using the Default/Airbuslongrange.set. I've tried to edit the file to remove the firetruck and ambulance (or even change them to a Van), but every time I do, when I restart xp12, the file is somehow being overwritten by the old default one. I also tired to edit a copy of that file and put it in the Custom folder. However, it then shows up as empty (no vehicles, nothing) showing at all.
Editing in TextEdit and BBEdit on a Mac as a pure text file. Had previously edited a downloaded set for the FF A350 and that worked fine. Seems to be something different with the Airbuslongrange.set. Any secret on how to edit this file?
