Topic: Problem wich activation SASL XP12
Problem wich activation SASL XP12. How to fix it?
JARDesign Group Board → Downloads, Updates. → Problem wich activation SASL XP12
Need some more details. Log.txt may help a lot.
Ok)
log.txt for X-Plane 12.01r3 (build 120103 Intel 64-bit, Vulkan 91a3101f936160070db2f56b774583362578dab2)
Compiled on Jan 19 2023 15:07:05
X-Plane Started on Sun Jan 29 22:04:04 2023
Hmm.. Please send to www.support.jardesign.org (attach there) a Log.txt file from X-Plane folder saved just after start X-Plane and load aircraft - I will check and inform you.
It's decided! I just deleted the ".key" files and activated license key again. Rebooted. That's it, the plane is activated.
ok, thanks for this info
