Topic: Copilot Plugin for FF 767 v.130519
So, this is CoPilot plugin for great Flight Factor B767-300
features:
+ animated 3d CoPilot model (male, "Sandy")
+ can recognize and execute voice command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ man and woman copilot model (man only included this time)
+ scripts based (possible to edit/change Procedures/Text/etc)
YourTube example video:
https://www.youtube.com/watch?v=t6Coc3O … amp;t=1024
versions:
130519:
+ basic release
This is a payware product with price 14.95 USD (VAT not incl.) You can download, install and test the demo version. Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key using X-Plane Menu ->FF767 -> CoPilot -> Registration and activate it.
STEP-BY-STEP
0. Check you are on MAC or Windows (no Linux, sorry)
1. Install and activate aircraft version compatible with CoPilot (FF767-300 v.1.2.13), check it work
2. Download and unZip CoPilot plugin Demo http://jardesign.org/copilotdownload/JD-CPL-767.zip
3. Setup speech/recognition engine at your computer (read manual in ZIP pack)
4. Install CoPilot plugin Demo to your 767 aircraft "/plugins/" folder. (read .pdf manual for details)
5. Load aircraft, reload if need, and check what you see copilot in cockpit, it animated, speak and recognize your voice command.
5. Demo mode work up to takeoff phase of flight.
6. If you prefer use full version, use X-Plane Menu->Plugins->YourAircraft->CoPilot- >Registration to run activation procedure.
7. If you use Ground Handling Deluxe plugin, please update set file (attached) at your ../X-Plane/resources/plugins/GndHandling/Sets/Default/ folder
UnInstall (if need): Delete 767-300ER_xp11.acf file from this aircraft folder. Rename 767-300ER_xp11.acf.backup file to 767-300ER_xp11.acf - you will get original .acf file. Delete "/copilot_main" and "/copilot_speech".
Please post your opinion, issues, troubles, ideas direct to this topic.
