Topic: Copilot Plugin for FF 767 v.130519
So, this is CoPilot plugin for great Flight Factor B767-300
http://jardesign.org/forum/img/m/22/t/p1d8tf9gniqk315nq1ekkm7e4b3.jpg
features:
+ animated 3d CoPilot model (male, "Sandy")
+ can recognize and execute voice command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ man and woman copilot model (man only included this time)
+ scripts based (possible to edit/change Procedures/Text/etc)
YourTube example video:
https://www.youtube.com/watch?v=t6Coc3O … amp;t=1024
versions:
130519:
+ basic release
This is a payware product with price 14.95 USD (VAT not incl.) You can download, install and test the demo version. Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key using X-Plane Menu ->FF767 -> CoPilot -> Registration and activate it.
STEP-BY-STEP
0. Check you are on MAC or Windows (no Linux, sorry)
1. Install and activate aircraft version compatible with CoPilot (FF767-300 v.1.2.13), check it work
2. Download and unZip CoPilot plugin Demo http://jardesign.org/copilotdownload/JD-CPL-767.zip
3. Setup speech/recognition engine at your computer (read manual in ZIP pack)
4. Install CoPilot plugin Demo to your 767 aircraft "/plugins/" folder. (read .pdf manual for details)
5. Load aircraft, reload if need, and check what you see copilot in cockpit, it animated, speak and recognize your voice command.
5. Demo mode work up to takeoff phase of flight.
6. If you prefer use full version, use X-Plane Menu->Plugins->YourAircraft->CoPilot- >Registration to run activation procedure.
7. If you use Ground Handling Deluxe plugin, please update set file (attached) at your ../X-Plane/resources/plugins/GndHandling/Sets/Default/ folder
UnInstall (if need): Delete 767-300ER_xp11.acf file from this aircraft folder. Rename 767-300ER_xp11.acf.backup file to 767-300ER_xp11.acf - you will get original .acf file. Delete "/copilot_main" and "/copilot_speech".
Please post your opinion, issues, troubles, ideas direct to this topic.
2 (edited by Wulfkai 2019-07-11 04:03:04)
Re: Copilot Plugin for FF 767 v.130519
First thank you once again for a super awesome plugin, i can't fly planes anymore without your copilot plugin.
regarding this 767 copilot, is also a magnificent plugin, however it seems that the copilot does not turn of runway lighting after passing 10000 feet. is this meant to be so or a bug?
thx in advance
Will the co pilot be ready for the cockpit upgrade upon release or does it need to be updated?
4 (edited by kazo00966 2019-08-09 02:52:08)
Since I installed the paid version of CoPilot for FF767, I got that -as seen in the attached image-, In the cockpit, can't use any buttons, all are jammed also, the installed Ipad for the 737 is not showing in the main plugin.
Can you please support.
dont write in in here if you want a answer from support mate, instead use: http://jardesign.org/ticket/kb/index.php
answer within 24 hours, remember to check spam folder wink
Any news regarding the copilot working with the modern avionics upgrade?
Anybody know if the She name is Linda female co-pilot works in the 767 Freighter version, because it does not say it doesn't in the sales description? The Sandy one does not work, bcs I bought that a while ago.
I downloaded the file from this page but I didn't have a male co-pilot, and the version listed in the txt file was Version 06.02.2021 which I found in the copilot_main folder, not in the OpenAndreadMe folder.  Linda can't seem to start the engines of the 767 in x-plane 12... do I have the wrong one?  should I have a male?
please www.support.jardesign.org with this issue
or directly via skype j.a.romanov - will check this issue on your side.
