Re: CoPilotPlugin for Zibo737 X-Plane 11
Not sure if this helps the developer but apart from the voice being ever so slow everything else regarding Linda seems to work ok.. If you choose select voice a lot of garbage comes up on screen in place of voices.  It seems as if it's trying to find the voices in the wrong directory. Im not tech savvy but that's what it seems to be.
27 (edited by yorkie380 2022-11-14 22:16:49)
Have managed to upload an image of the results you get when you try to choose Select Voice. Hope this is helpful.
28
understand
29
The sound problem occurs at both X-Plane 11 and X-Plane 12.
30
No details?
It only started in x plane 11 AFTER Apple upgraded to Ventura OS.It was also working in X Plane 12 OK until OS Update.
Hello Eugeny. You asked for details. I commented earlier. Linda is functioning normally on X-Plane 11 and X-Plane 12 except for the slow voice. That voice is terrible and makes Linda useless.
33
So I am back Ventura to iMac Monterey and enlisted Linda again as copilot. She is doing well again.
Ventura is new OS and have broken voice API what is not allow normally run voice apps builded on prev MAC OS versions. So, may be some patch will be in next versions or some explains about how to deal with this issue.
35
Thank you Eugeny. Keep me informed please.
36
Thank you for the info. Will keep my eyes open for any progress. Happy New Year
37
Secret meetings: just for two, one night only
Verified Damsels
38
Sir as a seasoned user of "CoPilot for Zibo737" would you so kind as to consider at the next update an option to be able to move the Text menues to a 2nd screen? Kind regards
