Topic: CoPilotPlugin for Zibo737 X-Plane 11
CoPilotPlugin for Zibo737 X-Plane 12
http://jardesign.org/forum/img/m/22/t/p1egnr0l6t1ss3lvdakilfg1rk14.jpg
REQUIREMENTS:
+ X-Plane 11.41-11.52 flight similator
+ Windows OS (7 .. 10) or MAC OS (HiSierra .. Catalina .. BigSur)
+ Microphone or Headset
+ B737-800X (ZIBO mod) aircraft version 3.43 (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
Pilot job in a modern airliner involves two people. As you are a simpilot, you need someone who can listen to you, execute your command, read checklists, live with you. You can get this with JARDesign Copilot plugin.
She name is Linda. She is well-qualified Boeing 737 F.O./copilot. She have:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
This product is not refundable, but You can download, install and test the demo version (Manual included) right now.
Actual version (250622) link:
http://www.jardesign.org/copilotdownload/JD-CPL-737.zip
Old version (150222) link:
http://www.jardesign.org/copilotdownloa … 220522.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key here https://store.x-plane.org/CoPilot-for-B … _1292.html
SUPPORT: www.support.jardesign.org
WHAT NEW:
250622
+ bug fix
220522
+ copilot logic improved
+ copilot movement improved
+ minor bug fix
090122
+ arrival runway identification fixed
+ "Ready for Secure Checklist" loop fixed
+ minor bug fix
171121
+ jetway power recognition add to electrical  power up procedure
+ add AC BUS recognition logic at electrical  power up procedure
+ NAV 2 drew input improved after Only Cat 3 Command
051121
+ electrical power up procedure auto start fix
+ electrical power up procedure GPU issue fixed
+ preliminary preflight procedure improved
+ preflight procedure improved
+ ILS freq set command add for CAT3 approach
+ add fast reject/abort command (may be assigned to button)
061021
+ plugin scripts was fully reworked
+ add "one button control" (please read manual)
310321
+ minor improvements
190221
+ Taxi Light switching logic improved
+ Transition and Approaching Transition logic fixed
+ Logo Lights logic add
+ Windows Heat logic add to electrical power procedure
+ Cockpit door logic add
+ Descent checklist "minimum" logic fixed
111220
+ Runway turn OFF lights command fixed
+ add Engine anti ice on/off command
+ add Wing anti ice on/off command
+ add APU off command
291120
+ bug fix
291020
+ altitude issue fixed
+ deicing checklist/procedure add
141020
+ random events add
+ landing rating add
010920
+ After takeoff checklist freeze fixed
180820
+ Initial release
Re: CoPilotPlugin for Zibo737 X-Plane 11
res
res
I would like to buy this add-on for my flights with the zibo mod 738, but yes, in a future support for the recognition of the Spanish language. Windows 10 works very well with speech recognition in the Spanish language and I think it would increase the sales of this copilot mod if it includes support for the Spanish speaking language. Just an opinion
hi
A problem with the emulator names disappearing, as in the image
could you please help to fix that
Just a image is designed here. Nothing else is been shared on the page but here if you people want to learn some new essay services review plans then here you have to choose the most important thoughts which are important for you to create these designed.
help in optimizing your site for search engines
<a href=https://kwork.com/optimization/13215554/fast-seo-website-promotion>website promotion seo</a>
8 (edited by adnous 2021-04-21 20:11:50)
I have a problem LINDA does not work after its installation it is not installed on the co-pilot's chair it is still outside the plane
in addition in the menu the option command does not contain commands and no voice in the menu
Thanks for your help
Hi, when will there be updates for these Copilots software. So Linda can execute commands such as MCP commands etc ??
Can this be used for other versions of Zibo, like 737-9U or MAX?
CoPilot for Zibo 737 was updated to version 061021, where:
J.A.Romanov    Thanks for the update 090122 it really helps to have Linda on board helping with the procedures , I updated today and will test it , I have a question ; When I update Zibo with the patches I do it manually by copying and pasting the update into the Zibo folder and I replace the files, the CoPilot for Zibo 737 files remain, it is necessary to reinstall the CoPilot for Zibo 737 plugins again or not or I can do it this way as I described and it doesn't affect any CoPilot for Zibo 737 files? whenever I update the CoPilot for Zibo 737 I follow the instructions in the manual so far so good.
for most of cases you may change copilot_main folder manually
thank you, I liked it Linda asks me, saying: your takeoff was good captain, now I want to see your landing.... ahahahahah fantastic, one thing I would like you to look at the course on takeoff and landing Linda always puts 1 degree less on the course of what is foreseen in the chart and also in the pressurization panel Linda adjusts the cruise altitude correctly but she always puts the landing altitude at 50 ft she cannot get the elevation information from the destination airport, maybe this information is not available in the FMS, I know this is complex, and it is related to the limitations of the FMS of the Zibo, this is just an observation, but if I can correct the adjustment of the course in the takeoff and landing, the landing altitude I adjust myself in the control panel. pressurization when she asks me to check if these values are correct. Thank you so much I'm loving flying with Linda.
Already tried that. Just after we add some abstract phrases - we get negative feedbacks, cause not all pilots want to hear something else than SOP smile Sure, the idea to make it "more live" - is good idea and we trying to find some ways for this.
New beta version:
150222
http://www.jardesign.org/copilotdownloa … 150222.zip
Please test and report issue here.
Linda changes the landing alt pressurisation according to the arrival elevation, which is correct. But lately I landed at EDDB (elevation 152') and Linda changed it to 2250' and announced that the landing checklist was not handled correctly! Is this a Linda or a Zibo problem?
Crash X-Plane 11 when I try to reload B738 Zibo: --=={This application has crashed because of the plugin: copilot_main/mac.xpl}==--
(Art controls are modified.)
99% of issues like this - missed some files or installation error. Please check installation or may call me Skype j.a.romanov - we will check issue on your side.
Hello Eugeny. I already mentioned per email a "Linda sound problem" after upgrading my iMac to Ventura. I am pretty sure that it all has to do with the new system settings in Ventura which are quit complicated as it comes to sound. The movement of Linda inside the cockpit is normal including the tempo in which she is working, but the voice rate (set to 100%) is half the normal one. So she's talking very slow (irritating). If you have the time and the possibility to look into the proper sound settings of Ventura, maybe you could give me some advice. I searched the internet to find a solution, but so far found nothing about Ventura sound problems this way??!!
I am trying to find solution in the internet too, but for now - nothing. This is most lovely Apple game - to "improve" something to make another things not working.
Thank you for your response Eugeny. Do you have the possibility yourself to test "Linda" on a Mac with Ventura? Just to find out if it is a general Ventura problem or just a local problem with the sound settings on my iMac. The problem exists on my iMac both with X-Plane 11 and X-Plane 12.
I also have the problem with Linda but only since updating to Ventura on 2017 IMAC.
Look like this is general issue with Venture. I read somewhere what intel CPU equiped macs will not support (or have stable issue) with speech recognition engine.
So, will there be a "Mary" for Mac owners in the future and say goodbye to Linda? Or case closed?
