Topic: XP11.50 JD330 v.4.3
http://jardesign.org/forum/img/m/22/t/p1e57cq5ln9odvjslepct41o5h3.png
JD330 for X-Plane 11.50
What new:
v.4.3R2
+ Spoilers animation fixed
+ Firetest sound issue fixed
v.4.3R1
+ xEnviro issue fixed
+ Avitab tablet add (switchable)
+ PFD indication improved
+ MAX and OPT FL calculation improved
+ window and display reflection options add
+ OXY indication fixed
+ OVH radio panel switch fixed
+ 2D displays widget add (work in cockpit only)
+ Flaps relief indication fixed
+ FCU lit indication fixed
+ FCU knobs reworked
+ mouse wheel manipulators add for most of switches
Download link for version 4.3r2:
http://jardesign.org/a330/download/inst … 0_4320.zip
Download link for old stable version 4.2r4:
http://jardesign.org/a330/download/inst … 0_4240.zip
For macOS Catalina / BigSur users - please follow instruction:
http://jardesign.org/forum/viewtopic.php?pid=31110
Download link to updated CoPilot version:
http://jardesign.org/copilotdownload/JD-CPL-330.zip
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
  - be sure, that you use X-Plane 11.41-11.53
  - copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
  - please visit download more fresh version of Ground Handling plugin (use link above). It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
  - enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.
(create it if need)
If you use TCA Quadrant - please open X-Plane Settings -> Joystick and assign command jd - "TCA_MasterSwitch1ON" on your Master Switch 1 ON position. Next - Open MCDU MENU -> SETTINGS -> Page 2 and set ON your TCA option. Next - you can deassign "TCA_MasterSwitch1ON" command if need.
- you may post you opinion about this version, post what you like/unlike
- please attach your log.txt if Crash happen.
Please care about information what you will post here and try to determinate reason if issues happen  - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
Re: XP11.50 JD330 v.4.3
Hi. So the wings on the plane are bugged. The spoilers are freaking out when I bank and stuff. Please fix this
3 (edited by thommy24dd 2021-09-20 11:10:55)
same here!
https://i.gyazo.com/6d1ac38d6870d97196d … db59da.png
++ no warning if Emergency Light is not armed https://i.gyazo.com/d4b35068d8bae2deefd … 1a8825.png
Will post updated R2 today. Thank you!
Ok, v.4.3R2 is here:
Can't launch the plane, it causes xplane to CTD, here is the LOG:
Hey guys. I downloaded the update and applied the PW engine mod, but now I am getting a systems error... I downloaded a fresh copy without installing the mod and to no surprise it works... Any help?
PW engine Mod is working for me.
Did you reinstall the mod or did you apply the update to the existing mod?
This happen for some of users. Work on it. Temporary solution it take /plugins/330/ folder from previous version and put to actual. Sure, you may contact me Skype j.a.romanov - we will try different solutions.
Please fix the fuel burn issue..A330 fuel burn is very less and lands at much more than expected fuel at destination airport. Please fix this.
13 (edited by thommy24dd 2021-09-22 08:24:19)
I did install the v4.3r2 fresh and installed the Mod after it.  I do never update an existing installation.
Ok, fixed now. But you need redownload and reinstall whole aircraft.
We measure, but not find bid difference. May be what was a wind what allow you decrease fuel consumption?
Anybody has the BBS trend sound pack? Doesn´t works with latest version of a330 (got BBS 3.0). I don´t have the sound menu in plugins and haven´t engine and overhead sounds.
17 (edited by CFG278 2021-09-25 15:16:14)
This work around does not work for me on my iMac (specs see screenshot). Also the reinstall with the current version does not fix my CTD problem.
Attachment icon Bildschirmfoto 2021-09-25 um 17.12.00.png 264.5 kb, 51 downloads since 2021-09-25
Attachment icon Bildschirmfoto 2021-09-25 um 17.12.00.png 207.69 kb, 57 downloads since 2021-09-25
BSS 3.0 properly working for me! Sound menu and and all sounds working.
I did install the v4.3r2 fresh and added the BSS 3.0 after it.
Hello JarDesign-Team,
would it be possible to make some adjustments in the FMC for future updates? Especially for flying online on IVAO or Vatsim it is necessary that you can put a DCT waypoint into the FMC which is not in your flightplan. At the moment (and I think it was always like that) it's not possible to do this. You can only use waypoints which are in the flightplan. The A330 is getting better from time to time but I hope you can fix/change points like this in the near future.
20 (edited by thommy24dd 2021-09-28 19:47:30)
I noticed that the menu "JAR A330.." with failurs and all this stuff is gone on the top menu of x-plane, there where plugins, development, Flight and things are located in the llast version
Yes, this function in our development plan
http://jardesign.org/forum/img/m/10523/t/p1fgmrsh751qna162m1dscku31h5r3.jpg
having this issue when the throttle goes idle the ENG almost shutdown . 4.3r2
Really shut down and can not run anymore? Or you just mean what N1 is too low?
24 (edited by LSPrado 2021-09-29 17:12:55)
I have the same problem but on taxi, after the start of the engines whenever I keep the engine idle it happens, and if I keep the engine it shuts down by itself, and this problem has been going on for a long time...
exactly sir the N1 is too low on taxi and app thanks
