Topic: XP11.50 JD330 v.4.3
JD330 for X-Plane 11.50
What new:
v.4.3R2
+ Spoilers animation fixed
+ Firetest sound issue fixed
v.4.3R1
+ xEnviro issue fixed
+ Avitab tablet add (switchable)
+ PFD indication improved
+ MAX and OPT FL calculation improved
+ window and display reflection options add
+ OXY indication fixed
+ OVH radio panel switch fixed
+ 2D displays widget add (work in cockpit only)
+ Flaps relief indication fixed
+ FCU lit indication fixed
+ FCU knobs reworked
+ mouse wheel manipulators add for most of switches
Download link for version 4.3r2:
http://jardesign.org/a330/download/inst … 0_4320.zip
Download link for old stable version 4.2r4:
http://jardesign.org/a330/download/inst … 0_4240.zip
For macOS Catalina / BigSur users - please follow instruction:
Download link to updated Ground Handling plugin to be well-compatible with XP11.50
http://jardesign.org/forum/viewtopic.php?id=11824
- be sure, that you use X-Plane 11.41-11.53
- copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
(create it if need)
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
