Re: JD340 v.1.4
PFD, ND, EWD, SYS displays 2D widgets add Does not work.
Best regards expec to answer for me.
JARDesign Group Board → Downloads, Updates. → JD340 v.1.4
The Transponder to change the squawk code is not working.
So tested again you have to hold the mouse down to adjust the squwak code.
If possible - please contact me via Skype j.a.romanov to debug it
Hello.
I sent you an invitation on August 6 on skype and I am waiting for you to accept me.
any resolution on the 2D widget issue? is it solved? I am at a loss here..as it doesnt work.
we expect solution within 1-2 days
Can someone test this build and inform me is pop-up displays work now?
http://jardesign.org/jd340/download/ins … 210821.zip
Thanks for the answer, I inform you that after downloading from the link that you put and installed this version in the 2D cockpit as in the 3D, the black screen continues, so I do not change anything.
All the best
All the best
Thank you! I just upload another build, where it should be fixed finally.
Thanks for the reply, I inform you that after downloading from the last link, the silly popup windows works perfectly in the position of 3D as well as in 2D.
a greeting
a greeting
Thanks a lot!
Can also confirm latest build does fix the 2D displays issue. Transponder still does the 0/7 thing if you use mouse wheel but is working fine if you hold the left button and drag, so its got an easy/viable workaround. Thanks for the regular updates!
If possible, could these updates be provided also in differential form (just those files new or changed since the base version) ?
Reinstalling the whole plane from scratch is a tedious process, as it involves not only reprocessing all files, but re-applying all customizations already performed (activation, liveries, plane specific plugins and such).
Of course I do my own "differential update" checking the date of files in the new download and comparing contents against the older; still isn't the easiest way to proceed.
Many thanks.
J.A.Romanov wrote:Thank you! I just upload another build, where it should be fixed finally.
http://jardesign.org/jd340/download/ins … 210821.zipIf possible, could these updates be provided also in differential form (just those files new or changed since the base version) ?
Reinstalling the whole plane from scratch is a tedious process, as it involves not only reprocessing all files, but re-applying all customizations already performed (activation, liveries, plane specific plugins and such).Of course I do my own "differential update" checking the date of files in the new download and comparing contents against the older; still isn't the easiest way to proceed.
Many thanks.
That is exactly what I would be interested in. I also find the reinstall very annoying.
_al_ wrote:J.A.Romanov wrote:Thank you! I just upload another build, where it should be fixed finally.
Many thanks.
You can always try and see if it works. Just backup your folder and see for yourself. In theory it should be possible because all needed files for the new version will be changed. However, to be absolutely sure everything works as intended you should reinstall. Especially when you have mods installed this can be the case, but since there aren't any yet you are probably safe to just overwrite.
hi jar design i wish to team up with your dev team since im making a 767 and if you wanna join let me know on discord https://discord.gg/teuaZX5q here is my server itll be a pleasure working with you
you may use Skype j.a.romanov - I am still not good in discord
russeladler10101 wrote:hi jar design i wish to team up with your dev team since im making a 767 and if you wanna join let me know on discord https://discord.gg/teuaZX5q here is my server itll be a pleasure working with you
well i guess we can talk through xplane forums and ill just tell you everything
The copilot immediately after take-off hangs up to 10000 feet. Try to fix it.
Hi there.
Today this capture is still released by Facebook, is it true or is it a hoax?
waiting for your reply.
Are you mean unregistred/demo version? Or full version registered with serial key?
And what happen wrong exactly?
Hi there.
I just add link to version 1.3r1 to the first post of this topic.
Thank you very much for your answer, I lower it and I will always put the comments in positive.
Best regards.
Hello.
I get in touch, for the reason I have bought the a345 JD, in all the previous updates, I asked for the serial to paste it and activate it without problem.
Today I am trying to put the update in my holiday home that is another pc and tells me that the license is expired.
I hope you can give me a solution to enjoy my newplane.
I can't find where to put a tiket for this product.
