Topic: CPL A321
After update a A321 TOLISS to v1.3 dont completed the flight control check... specifically does not listen to the rudder command...
JARDesign Group Board → CoPilot for TL321 → CPL A321
I'm having the same problem.
...and not disabling speedbrake during After Landing Procedure...
I have this for the Toliss A319 also and it still works.
I was having the same issue after 1.3 update. Here is a workaround I just tested:
Make sure your original files are backed up before you modify them.
In the CHECKLIST.txt file, change following lines from 27 and -27 to 20. The original values of the lines you need to change are 27 and -27. Do not touch the lines with values of 0.5 and -0.5. You can try with an even lower value if this does not work for you.
[SYSTEMS.FLGHTCONT.Rudder]
It should be like this:
[SYSTEMS.FLGHTCONT.Rudder]<[-20.000000]
[SYSTEMS.FLGHTCONT.Rudder]>[20.000000]
its working thank you so much!!!
After updating to 1.3, Linda disappeared but can be heard. Please help.
This is always happening. Best to re-install it, or try re-setting the voice recog from the menu, and re-load aircraft from dev menu
HUH? 1.3? Are you talking about Toliss v1.3.x? Im running the latest of both Tollis and this addon and there is no such option in my checklist.txt 27 nor -27 and YET IM STILL HAVING THE RUDDER issue that Linda cannot see. So this is not a fix.
