Topic: v1.1b5.2 distributive mostly the same b4 + new base SASL plugin
v1.1b5.2 distributive mostly the same b4, but with new base SASL plugin for Tests.
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
If you have a CTD at MAC, please place reports direct here (log.txt file and MAC crash report). This version build to understand how new mac os SASL base plugin stable on MAC.
Download link http://jardesign.org/a330/download/inst … .1b5.2.zip
- be sure, what you use X-Plane 10.35 or later
- copy unziped "330_JARDesign" folder to ..\X-Plane 10\Aircraft\ folder
- start X-Plane 64 bit and open a330, activation window is show up
This is beta version for X-Plane 10 64 bit.
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
If your activations are over - use contact form at official website http://jardesign.org/a330/
