Re: XP11.50 JD330 v.4.2
jcdp wrote:Hi
About engines ...
After a try for recalibrating "yoke" I have no change when engines are shut down ... from outside view blades of turbines keep rotating ...
so I shall try to contact you on skype ..
regards
jcdpEdit: Curiously this doesn't happen with A320 (same config )
So, from outside view blades of turbines keep rotating, but what about EPR and N1 indication on EWD?
Of course EPR and N1 indications are correct ( Engines down) , only blades keep rotating and smokes behind turbines ...
but this doesn't allow passengers bording bridges to work .
What to do for getting them to work ?
This does not happen with A320 .
PS: Otherwise A330 is perfect .
