Re: v1.1b4 distributive (Windows 7/8, MAC OS)
that's really good news! Hope this version will guide you to the bug! Good luck with it!
JARDesign Group Board → Beta-versions (Download & Discussions) → v1.1b4 distributive (Windows 7/8, MAC OS)
this is good news thank-you.
I get debug version of SASL plugin for MAC and start developer tests.
CTD
OSX
line up for departure at EDDE
Mac OS
taxing in EDDL...CTD
Hello people, maybe the problem is already known, for me, the program of the A330 supports / beta4, as even with the versions being off regularly on the way to the runway! This experience and solutions exist? have a good flight - Klaus
CTD on 1.1b4
lined up on 28R @ KORD, looking at over head panel.
OSX 10.10.3
logs attached
If mac - yes, known problem with no solution now. Just wait a new SASL version.
Hello JAR team, today I have for the first time flew the A350 for X-Plane / Mac. A wonderful flyer with many beautiful details, a great job. During the test flight from EDDF to MUVR the program has crashed unfortunately after 1:30 flight time. It is probably the same problem as in A330. Otherwise, I could not find bugs, everything worked as far as really great! I hope that with the Programmabstürtzen can be resolved, then this Airbuses are the top on the simulator market! Thanks in advance for work ..... I wait patiently - Klaus
Hello again, i test the beta Version A350 with my Mac and X-Plane 10.35 three times, all Test crash the Program in diffrent times. Flying is not going on in this modifikation :-( Fly Airbus A320 from Peter Hager now.....Klaus
I think weather update is not working...
i think you use not default weather program. NOAA weather 2.1 is created default metar file for x-plane (a330 read default metar file), other weather plugin not sure. If you use 3d party plugin try write message to 3d party weather plugin creator.
Hi there,
This version does not work for me at all. Crash-to-desktop as soon as I load the aircraft.
Log attached.
Hi there,
Log attached.
You just need reinstall it. your installation was wrong. Follow instruction.
CTD
OSX 10.3.3
Vatism Online-Flight EDDK-EDDF, descending, want to change the approaching runway in the fmc.
Clicking on the button on the left side "eddf" in the flightplan, x-plane crashes.
When you get a CTD it helps to get the Apple Problem Report since, that has the information about what happened on the Mac.
The two file you sent helps but does not tell the whole story of the CTD.
thank-you for your help.
CTD
OSX 10.3.3Vatism Online-Flight EDDK-EDDF, descending, want to change the approaching runway in the fmc.
beta 5 with new MAC SASL base plugin will post tomorrow.
Great can't wait!!!
MRachowski wrote:Hi there,
Log attached.
Thanks. Reinstalled and working now.
