Topic: v1.1b4 distributive (Windows 7/8, MAC OS)
Please install it as clear installation, not use custom sound pack, not mix files with other version, but sure, install NavData update if need.
We always have a CTD at MAC (still not get a test-version of SASL plugin from developers). But, please try a little trick - after loading a330 in airport, please move it to some another sting/gate.
As soon as you will update your AirFMC it will be support a330 with this beta4.
Download link http://jardesign.org/a330/download/inst … v1.1b4.zip
Whats new: Please use v1.1 tag like this http://jardesign.org/forum/search.php?a … ;tag_id=52
Also, please check "whats new"with link above. Please not post old issue what always reporter but not done/fix at this version.
2 (edited by pcartier 2015-05-08 12:39:07)
Re: v1.1b4 distributive (Windows 7/8, MAC OS)
Thanks for the update JAR! love getting these new beta's question, is there a log of what is fixed/updated for the latest beta?
Noticed before takeoff from a cold & dark state  i clicked the PA and selected to "notify the FA that we are ready for take-off" but the recording said "FA prepare for landing", then I clicked it again and the "Prepare for take-off" message played. I will try this test again tonight.
Also noticed a FPS drop with this beta by 2-3FPS after activating and loading the aircraft again. (I will re-check later)
As mentioned above, http://jardesign.org/forum/search.php?a … ;tag_id=52
Thanks jiggyb2 didn't see that
Thanks for info.. I think thi is course i add big part of code to may 330 compatible with AirFMC. May be I need make it execution as an option with menu settings.
wow, another Beta! You go forward really fast, this is much apprechiated! Will load it and do a flight soon
That would be a good idea any add-on options can be "enabled" via the a330 plugin menu. "Enable AirFMC"
8 (edited by captbullett 2015-05-08 21:55:55)
I noticed this;
"We always have a CTD at MAC (still not get a test-version of SASL plugin from developers). But, please try a little trick - after loading a330 in airport, please move it to some another sting/gate."  J.A.Romanov
I did this today , but using version //* JD V1.1B3 , there was no CTD, I was using "South Florida Scenery Package" By Ted Davis and the KMIA in that package.
2) I moved the A330 from the default loading spot when X-Plane started to a gate from the scenery package.
3) I loaded the fuel needed for the flight route KMIA to TNCM 26011KG using the http://onlineflightplanner.org
4) I set the cabin up and taxied to runway 08 and had a good takeoff, I am still in-route and will have another good flight after this flight I will download the v1.1b4 version and start testing it.
5) I have had no CTD's except due to my fault not the computer or software... //
Note : downloaded v 1.1b4 and did the move of the aircraft like the instructions asked and no CTD's this is still a stable aircraft for me and always has been. if you need any more information please let me know.
9 (edited by zek0 2015-05-08 17:25:27)
we wait solve problem with sasl. Good practice after loading - moving aircraft to other position. After this we are prepare to fly (just some spoiler smile
Thanks for another Beta. It gives some confidence that work continues to fix this for Mac.
takeoff.......
12 (edited by captbullett 2015-05-09 23:30:53)
First CTD because of the Sasl issue,
... and right before takeoff ... and this is when I did a region move of the airport from TNCM to PHNL  to run a PHNL to KLAX and I had to minimize the screen to set-up the Flight Plan which took 15-20 min. to enter into the UFMC ...
http://jardesign.org/forum/misc.php?act … tr=49t1021
Attachment icon Apple Problem Report for A330 JAR V1.1b4.txt 47.56 kb, 339 downloads since 2015-05-09
13 (edited by captbullett 2015-05-09 23:36:15)
good day,
as this version does not work I am rolling back to version 1.1b3
14 (edited by alessandro61 2015-05-10 07:19:13)
Good Day,
here we are with CTD
Attachment icon X-Plane_2015-05-10-091033_iMac-di-Alessandro.crash 64.3 kb, 283 downloads since 2015-05-10
good day,
as i see at log, this not depend b3 or b4, but you get error in lua code. If it possible, and if this can be repeated, can i get description what need to do to repeat this? may be via Skype j.a.romanov
16 (edited by captbullett 2015-05-10 16:41:11)
This is a CTD using version info VER 1.1b3 04.15 ...Sasl, and yes this is now happening every time either when taking off or just after take-off.
//* I do not understand Skype I do not use it.// [I you need me to use it Please give me instructions] on "FaceTime" as this is what Apple calls Skype...
If there is any thing else PM me
captbullett@gmail.com
This did start after I reloaded the "Office suite" Word,powerpoint, Excel, Microsoft outlook; so i do not know if a component of one of the MS office has a issue with XP...<?> [Just thinking out loud]  this  was removed while I was testing during the 10.8.5 OS X testing.
I was doing on several aircraft including the Bell412,F35B, 757, A330 , SSG 748-I and the theory that the 10.10.X (2,3,4,)Yosemite OS X was the cause of the CTD's
To reproduce flight:
I start at PHNL depart RW 08 /FL 320 and set-up all other flight constraints per manual ... and UFMC ...
PHNL SID PALAY KOLTE ROSHE HAVBI ZULBI HUKLA AWAHI AZIBA TANFO ALICA EBBER ELOYI ERROT ETNIC ETECO EDSEL EDTOO  ELKEY BEFIN  PERCH STEMS TIMSE ZERAN KLAX
Note: no STAR at the end because it is already there //STEMS TIMSE ZERAN //  land 07L LAX
Note: as you see in Attachment #4, and #5; shows the messages in the Apple console due, to the playing of the //*sound 1d,2d,3d plugins..//
# 6 show the output of the Developers console report showing the sound driver working .. right or not <?>
Note:#7 is a screen shot of setting to set-up the reproduction of the flight from PHNL to KLAX
Note:The console message gives you the right information as, to what is going on so, I took a screen shot of the message ...
FINAL NOTE: when I went from 10.8.5 to the 10.10.3 that I am running now, the Flash player and Java scripts had to be re-installed this step I did over looked.
Since, I re-installed the aircraft is working again this is 1.1B3 that is installed and i am running  KDTW to KLAX for the first route after the issue. FL320 and the other setting as per the manual and UFMC settings.
Thank-you for your time.
good day,
Attachment icon Screen Shot 2015-05-10 at 10.33.48 AM.png 172.08 kb, 213 downloads since 2015-05-10
Attachment icon Screen Shot 2015-05-10 at 8.46.56 AM.png 632.48 kb, 188 downloads since 2015-05-10
Attachment icon Screen Shot 2015-05-10 at 9.04.07 AM.png 22.81 kb, 199 downloads since 2015-05-10
Attachment icon Screen Shot#7 2015-05-10 at 10.33.48 AM.png 172.08 kb, 223 downloads since 2015-05-10
excellent , bringing this down now
Emma Bentley
Apple Mac Studio M2 Max , 38 Core GPU
good day,
Cool! Thanks!! Will try.
19 (edited by Luke173 2015-05-11 04:49:27)
I had my first good flight with no CTD yesterday.
Route: LSZH LFBO
X-Plane 10.35 latest with no addons (no global scenery)
No additional Plugins
Mac OS 10.9.5
Yay big_smile
20 (edited by captbullett 2015-05-11 12:07:39)
" (no global scenery) " with out scenery in the XP world the ride must be a blank slate, and very boring to look at
as global scenery is one of the main folders so removing it means that there would be a bug in the 10.35 issue of X-Plane,
now if you now can run the A330 w/o global scenery.
I suggest that you use the XP installer and re-install global scenery making sure that no file have been damaged.
Therefore, you need to go to the X-Plane website [ http://www.x-plane.com/downloads/x-plan … r-updater/ ]; up-date X-Plane using the latest installer from the X-Plane website. This will check to see what file need to be installed and re-install the right ones also, install any damaged one that might be causing issues.
Route: LSZH LFBO
Mac OS 10.9.5
Yay big_smile
Hey Captbullett
I have this clean version to build custom sceneries for the gateway, so I don't use other objects than the default XP ones.
And I don't think the Global Scenery will affect the A330 in any way. Here it's just a matter of space.. 2x a full XP installation eats up a lot of space..
And yes, the flight was rather boring big_smile
(btw I didn't remove the GloS, I just didn't copy it from the "normal" installation, also for the installer/updater nothing is missing, it doesn't check the presence (or absence) of the Glos..)
Luke
CTD
osx during departure (pushing a joystick button to change view from outside to inside view)
Good Day,
very much understand the issue of clean install for scenery building smile
Luke173 wrote:
Hey Captbullett
Luke
I get debug version of SASL plugin for MAC and start developer tests.
That is great news. Thank you JAR!
