Greazer wrote:
Because X-Life is a horribly designed and developed product. Is hardly even supported by Developers. And paying customers have to deal with the most ridiculous bugs and errors.  Almost as bad as Vulkan!
I have the same openion.
No response of the developer on bugs.
The developer was waiting for XP 11.50 to get final and now when X-Plane is final, there is no new release of X-Life. Customers can pay for the buggy software and get no aftersales.
I tried for the first time today, using X-LIFE with XPlane 11.50,  with and without Vulkan enabled.  In either case, X-Life now gives errors while loading, saying several specific X-Life aircraft files cannot be loaded.  Now, there are  no visible X-Life aircraft visible, on the ground or in the air.   X-Life works fine, on previous version of XPlane,  XP11.4.
HP OMEN computer, I7, 3.6GHz, 32GB RAM, Nvidia RTX2080, 12GB VRAM.
FYI, XP115 log file attached.
53
X-Life isn't working for me on 11.50.
I'm only getting win.xpl errors and X-Plane crashes instantly....
Hope there will be a fix any time soon...
This addon is junk.
55 (edited by worracnan 2020-09-29 03:49:07)
Hi...when or will xlife deluxe be updated to 11:50r3?...I have tried  with both open GL and Vulcan...both versions it crashes on loadind the xlife screen...thanks...
Bad News:
+ to work with Airport Editor tool - need to save XP11.41 at your hard drive
(hope will fix for XP11.50 laters. When?
X-Life is working for me in XP 11.50, the only problem I'm seeing on my setup is I see aircraft outside but nothing is showing on TCAS.
There was no problem on on XP 11.41, it on happened after update to XP 11.50 running Vulcan.
58
Yes X-life working with XP11.50, but must be some updates to do.  Loading time is enormuos long, when I turn on X-life X-plane freeze for 2 minutes until X-life loading. And many time when i use X-life, X-plane freeze and must be closed. No warning in log files, but last input is that X-life loading some aircraft. So for now i don't fly with X-life anymore.
JAR did not comment any of ours posts and not give us any hope that be some inprovement in X-life and in FM too.
59
Airport Editor not working in XP11.50
60 (edited by carlos9235 2020-10-21 20:07:21)
Hi! just updated X-Life to new version for X Plane 11.50. When it starts some errors come up about loading aircrafts, so no aircraft is shown in the airport. Find attached LOG file. Thanks!
61
No answer? so there is no support on X-Life Deluxe edition? uninstalling...
I did do a support ticket for the issue I'm having with TCAS, see post 60, JAR replied it would be corrected in a future update, he didn't say when it would be.
Any idea when we will see the update to X-Life 4.20-070420 for XP 11.50, so we can see aircraft on TCAS ?
It was promised a while back.
64
Is there any hope that we'll get working airort-editor under 11.50? Seems to me that project is dead since some month.
No news from the JAR group. Looks like this project is dead. Buyers would deserve at least honest information or something else they are working on this project.
Running XP11.5 without Vulkan.   X-Life DeLuxe user for over a year now.   I too get file loading  errors, such as ...  "X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a330/anim.obj ".  See attached screen capture.  I do have traffic on the ground and in the air, so X-Life appears to be working.  I use only the B737-800X aircraft.  But the file loading errors crop up from time to time during  a flight, and are very annoying, especially when recording a flight for YouTube.   I see that others are continuing to have similar problems with X-Life DeLuxe.   It works OK with XP11.4x.
67
Sadly not much seems to be happening with the promised update to correct problems, I see aircraft outside but nothing on TCAS. I did a support ticket and was told things would be corrected in an update, nothing so far.
I'm using 4.20-v070420 for XP 11.50 and the issue only started when I update to XP11.50.
68
I am frustrated with the Deluxe version as well. I. tried again today to use it but ATC kept me at the hold short line for 15 minutes with no planes landing or departing. I gave up and canceled the flight.
You don't have to cancel the flight, you can just take off. You will get told by ATC that you took off without permission and then it carries on and hands you over.
70 (edited by vipt20 2020-12-04 21:50:22)
Hi, I just joined the forum as I am having trouble with EGKK.  The aircraft is showing as on runway 08L/26R when either queuing for 26L or when on the taxiway next to 26R to go towards 08R.
This means that landing aircraft do not cross 08L/26R after exiting the runway so they queue up waiting.  If lots of planes land then they do not clear the the active runway 26L/08R so I do not get clearance to takeoff from ATC.
Is there a fix to this to stop my aircraft showing as on the runway 08L/26R when in these scenarios?
I am no longer able to use X-Life. Have been a user for the last couple years off and on running between X-Life and World Traffic. Crashes prior to TOD Now essentially useless running in Vulkan. Not fun flying without traffic or ATC.
72
Hi J.A., recently bought X-Live DeLuxe and am happy with traffic and ATC in general, BUT I get irregular stutters where GPU processing virtually stops for a few seconds. Doing the exact same flight without X-Live no problems. Sliders in settings at center position. When the stutters happen neither CPU nor GPU parameters are at their limits. Win10 Professional, i7-6700K, 32GB DDR4, RTX 2080Ti, Samsung SSD.
Tried various Nvidia drivers but overall pretty much same problem.
ATC, while showing weird radio frequencies, (which is not that relevant) is a great feature. Traffic + ATC provides a meaningful boost to realism!
Hope you have ideas how to remedy the stutter side of things.
73 (edited by andrey7907.79 2020-12-12 09:33:04)
When approaching some ports (efhk as an example), when communicating with the dispatcher, the simulator crashes.
74
Loaded v4.21-111220 and did a flight from LEBL to LEMD, X-life worked without any problems, but I'm still not seeing aircraft on TCAS, although they are showing up on X-Life radar.
75 (edited by Darko24 2020-12-18 18:41:15)
Thank you find new version. Even I read you, I spent some time to find this version. I think that new version could be assigned in new posts from developer.
I'll try and X-life worked without any problems, with same problems on TCAS as you say, and not show frequencies whwn you are on center TAB.
