Re: JD320 Airliner ver 3.6 WIN/MAC 64 bit (X-Plane 11.50/11.41)
What is the latest BSS sound pack version for JAR A320?
JARDesign Group Board → Download, Updates → JD320 Airliner ver 3.6 WIN/MAC 64 bit (X-Plane 11.50/11.41)
todays fight EGHI - EBBR
In midair : ( all on Auto )
-overspeed
-no more thrustcontrol ( manual ) possible
-to avoid overspeed I uses airbrakes
-the ECAM page selector buttons stopped working
-after some time I initiated the descent to EBBR
-Automatic reduced thrust to 0 and started deep decent
-after some second ..
-X-PLANE crashed
I think an update is neccessary !!!
another bug :
Approach
- If selecting eg EBBR RWY 25R ILZ Z
- in the RADIO NAV page it will no select the ILS IBR 108.9 but something elses frqueny
This is the current version.
JARDesign A320 CFM Sound Expansion Pack v5
https://store.x-plane.org/JARDesign-A32 … p_428.html
Hello, I'm having trouble with Jardesign A320 3.6R2. I'm using X-plane 11.50 and the autopilot does not engage. When I push the CMD1 button, the light goes on but the autopilot does not engage.
Need help, please.
I have a stutter with both the A320 v3.5b2 and the v3.6r2 in the current XP11 v11.50r3, as shown in the video.
With other aircraft, e.g. Zibo B737-800X, the stuttering does not occur. What can that be?https://www.youtube.com/watch?v=i4K5dD5x7uI
Thanks and Regards
So, I was able to clarify the cause of the video stuttering so far that I could turn it off.
I installed Python for the NOAA weather plugin and here 2 Python scripts (PI_GroundServices and PI_xJoyMap) caused the video error.
This error only occurred from X-Plane 11.50r3 with the JD A320 v3.52 and v3.62r2 as well as the A330 v4.0r2. Maybe the developers can say something about this.
Horst
Hello- Help me please how to manually change the altitude and speed on the flight plan in MCDU for a specific waypoint. Thanks you.
It seems feedbrakes are not working well in R2 version. Not possble to extend them during landing either if they are armed nor manually.
Yup.
That and several other glitches.
Parkbrake jumping to the ON position every time during take off roll has had me shelf the A320 until they fix it.
Dear Sir;
I so interesting in flying with Jaed320
But from the image, I upload for the speed and FL indicator is so dark for a night flight.
How to fix this problem?
i am having a problem turning the autopilot knobs in virtual reality. how can i fix this? when flying in virtual reality i can't urn the speed, heading, altitude, or vertical speed knobs with the motion controllers or mouse.
Is the automated checklist no longer available along with the toolbar to access doors etc?
Was easier to use via the toolbar.
Hi Sir!
Would it be possible one day that we could use all the features of the Thrustmaster TCA Quadrant Airbus Edition?
At the moment the ign start, start eng 1 and 2 buttons cannot be used. Maybe a plugin is needed?
Thanks a lot
In the Joystick settings for TCA Quandrant I don't find the command jd - "TCA_MasterSwitch1ON"
May you help us
hello
quadrant working fine for me, but the flood light in cockpit dont work anymore. (FLOOD LT MAIN PNL)
Hello everyone,
I´m totally satisfied with this little birdie. It´s a great product you´ve have greatet there! Thanks for your efforts!
But with version 3.6 I´m totally confused. How to hide the pilot and the co-Pilot characters? I donb´t get it! And with my Track IR I´m sitting e"Directly in their heads" and their glases and mics are swapping infront of my eyes, so itß´s nearly impossible to land correctly because always something is hidden by the grafics of the Pilot/co.
Another thing I noticed: Some buttons are not working anymore. For example, in the start up procedure, you have to set the autobreaks to MAX. I can´t press that knob, it´s not reacting, even the mouseover doesn´t change. The Master Caution and Warning Knobs are also not working.... is it a bug or do I do something wrong?
Thanks for your support,
Greetings from Germany,
Toulouse.
Another thing I have noticed as well, is XChecklist plugin resets when updating the inflight Weather.
The break pressure dial doesnt show pressure sometimes in Green after Pressurizing the Yellow Hydraulic System and doing a break pressure check.
Could it also be made that when doing a turnaround flight,, that the cabin announcements work after entering a new flightplan.
hello
Do the switches work fine too ? Engine 1 & 2 don't work nor the middle switch (crank, ign start ,etc)
May you help us
Now with the good link to the R4 version, I can find the command "TCA_MasterSwitch1ON" and I apply the settings in the MCDU... but nothing happens when I use the switches and the Crank/start switch...
Palpatine wrote:hello
hello,
for me its working, did you download the drivers from trustmaster ?
I use the TCA throttle hardware and I can not find the jd320's set button crank /mode norm and ign/start selector ,and the ENG start button as well ,please tell me how can I set those button for my throttle?
TCA Quadrant usage issue not be fixed!
since some days my A320 is unable to catch the LOC during a ILS approach. It was working weel and now it does work anymore even the LS is armed. I have no mark (glide and HDG). Of course ILS frquency is well setted on FMD.
Any idea ?
since some days my A320 is unable to catch the LOC during a ILS approach. It was working weel and now it does work anymore even the LS is armed. I have no purple diamond (glide and HDG) on PFD display . Of course ILS frquency is well setted on FMD.
Any idea ?
Thanks and regards
Any idea ?
Thanks and regards
Look like you have not ILS approach type, so ILS in this case only for information.
