Topic: JD320 Airliner ver 3.6 WIN/MAC 64 bit (X-Plane 11.50/11.41)
WHAT NEW:
RC1 (release candidate):
+ X-Plane 11.50 compatible
+ X-Plane 11.41 compatible
+ Vulcan/Metal/OpenGL support
+ Fly-By-Wire system fully reworked (based on Visual Avionics)
+ Migrate SASL2 to SASL3 base plugin to improve performance
+ TCA Airbus Quadrant "plug-n-play" support
+ GHD plugin will work with JD320 for free, no payware serial key will need
(updated GHD plugin with this feature coming soon)
- sidescreen widget is gone, please use MCDU MENU to operate all
- voice checklists gone, please use JARDesign CoPilot plugin if need
RC2
+ vertical profile calculation improved
+ go-around operation improved
+ bug fix
R1
+ FCU knobs manipulator reworked (usage with mouse right/left buttons & mousewheel)
+ VR manipulator for FCU reworked (can be switched via MCDU MENU->Settings)
R2
+ /plugins/fmgs/win.xpl and mac.xpl files updated cause of widgets issue
R3
+ speed constraints issue fixed
R4:
+ TCA Quadrant usage issue fixed
JD320 Download link:
http://jardesign.org/a320/download/inst … 0_3640.zip
Actual CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
- Please not mix files with other version.
- be sure, what you use X-Plane 11.41-11.50
- be sure what you set Control Sensivity of your to default values
- be sure what you turn Off X-Plane experimental flight model
- download and unzip pack. Open and read OpenAndReadMe folder
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode) and after a successful activation reopen the aircraft via X-Plane menu
- if you use BSS soundpacks, please note what "Modules/Custom Module/" now is the same as "Custom Avionics/" folder
If you have security issue with MAC OS Catalina - please follow this instruction:
http://jardesign.org/forum/viewtopic.ph … 110#p31110
- “JARDesign 330/330 Native format” and put a new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create it if need)
Thank you!!!!
