Topic: A few issues
Hi Mr. Romanov! Thanks to JarDesign team for this nice addon I bought a few days ago. It works almost fine on my sim (latest 3.43.7 Zibo mod and XP 11.41) except for a few bugs I'm experiencing. I don't know how but it interacts a bit heavily on the aircraft systems: for example, it does not allow total freedom to act on some instruments allowing only Linda to press some buttons and only rigidly according to the sequence of procedures. Furthermore, both the Avitab tablet and the FMC switches often get stuck and do not accept the inputs I select. Only after many, too many attempts - randomly as it seems to me - the input is accepted allowing to continue in the aircraft settings. In short, Linda has finally populated the loneliness of the flightdeck and gives a lot of fun to work with her but if the few bugs it causes could be fixed then this addon would be perfect. Thanks again.
EDIT: for further informations I've experienced that I can get rid off the fmc switches to get stuck if I make the same selection in the FO fmc and/or the FO Avitab tablet instead of the captain ones, then the aircraft accepts the inputs.
