151 2020-08-18 17:07:29 (edited by Webrichard 2020-08-18 17:18:29)
152 2020-08-21 09:50:39 (edited by Steiner3D 2020-08-21 09:50:57)
Re: XP11.50 JD330 v.4.1
This is what every screenshot of the 330 looks like, and when I try to stream it, it looks like this too
You can stream this aircraft with OBS if you stream your desktop instead of the simulator. You can set your Windows task bar to automatically disappear when the mouse is not over it. I know this is just a work-around, but it works.
Hi. All these observations are in comparison the new 4.0r1 vs 4.0.5b.
This latest version 4.0r1 presented me with the following faults:
1. Do not lower flaps with key or button, with the mouse if you let down, to go up if you leave with button or key.
2. Rotating for takeoff deployed spoilers on their own.
3. The climb to FL370 was too slow after FL200. It lasts too long and almost 300nm from takeoff. With 4.0.5 climb almost 125nm.
4. Fuel planned for 4h20 runs out at 3h.
Hmm.. Yes, confirm. As I see - this is FPS_boost version issue. Please use non-FPS_boost version untill R1.
The APU Master and Start are not animated
My serial number can't activate airplane.
I have followed the steps to send mail for you.
Please help deal with my issue, thanks.
please www.support.jardesign.org
This is solved for v4 RC2
159 2020-09-04 17:40:42 (edited by gsnipe 2020-09-04 19:06:15)
Hi! I've downloaded the JAR 330 today and I'm quite impressed with it. Great job!!
I've one question for you, I noticed that after starting the engines, a LOT of black smoke is generated by them, and I'm not really sure if I'm doing something wrong or if it is something that needs to be addressed.
XP Version: 11.50RC3
JD330 version: 4.0RC3
Thanks,
Guillermo
Try Pressung the x key.
162 2020-09-05 11:02:00 (edited by gsnipe 2020-09-05 11:05:46)
I also noticed that the CPDLC screen is not working on JD330-V4.0 RC3 as it should. It freezes whenever I press "update" after loading a FPL. (SAEZ-KJFK), find the FPL attached.
Repro Rate: 100%
Addons: ASXP, UWXP
XPlane version: 11.50 RC3
(On a side note: Enabling the GPU by pressing the green text that appears on the left bottom side of the screen, also causes a small freeze (2-3 secs)
163 2020-09-05 18:40:28 (edited by gsnipe 2020-09-05 18:41:02)
I just finished my first flight (11hs block time ), and while there are many things I need to get used to (I didn't find the way to control the plane using the HDG mode, pushing, pulling the knob, there was no way to do it) there is only one thing that I would like to suggest as something that needs to be fixed:
Some rotary knobs, as the radio ones... I found myself dragging the mouse all over the cockpit to switch to some frequencies. Same things goes for some other switches like the cockpit lights, etc. They should definitely work as the press alt selector works.
I do definitely think the plane is great, it's definitely the best payware addon that I've tried for XPlane, big kudos to the team.
Today, on my second flight (back from JFK to SAEZ) I noticed that after getting a clearance to proceed dct to a waypoint a few miles before the TOD, the TOD vanished from the FMGC.
This is definitely quite a severe bug.
Guillermo
Guillermo
Perhaps when you went direct, it put you past your TOD?
gsnipe wrote:Today, on my second flight (back from JFK to SAEZ) I noticed that after getting a clearance to proceed dct to a waypoint a few miles before the TOD, the TOD vanished from the FMGC.
Guillermo
No, in fact I asked a friend of mine who also owns the plane. He is also experiencing the same issue. You will also find the bug reported by some other users in this same forum, but thanks anyways
167 2020-09-10 04:39:57 (edited by MiesterMoose24 2020-09-10 04:40:47)
Just my opinion, I'm in love with my Version 3 with an Fmod sound pack. I feel very familiar with it. The co-pilot is very helpful, and all the sounds work. My rudder bug sorted itself out somehow, so, not going to touch it. Version 4 also MURDERS my frame rates, but version 3 is not so bad. I don't seem to be having the other bug issues like other users, so, I'm set.
Awesome Job Mr. Romanov
When I click on the update link, it says page not found. If someone could help that would be awesome
page not found, when I click on the link!
170 2020-09-10 20:38:50 (edited by aviv.ps 2020-09-10 20:44:29)
Hi I try to download the A330 v4.0 but the link you published not found.
the A320neo I download without any issues.
can someone help to solv thia issue?
Aviv.ps
the download link doesen't load
172 2020-09-10 21:24:50 (edited by jcpaisa86 2020-09-10 21:44:13)
Link to download A330 is not working.. this what comes up after i click on the link.
Download Link fixed. Sorry!
V4 work better with XP1150.
Also it have "FPS boost" version what should increase framerate.
When I load into the plane and activate it, I am not able to pull up the toolbar with the plugins and stuff on the top of my screen. So I cant reload the plane. If someone could help that would be awesome
