Re: JD320 Airliner ver 3.6 WIN/MAC 64 bit (X-Plane 11.50/11.41)
peterg wrote:
I miss the checklists, because the CoPilot crashes me as soon as I try to call them up.
Did you call copilot plugin or instant copilot or what?
peterg wrote:
During landing the Airbus starts to shake when I try to make small corrections via the tail rudder.
We will check this, thanks
I can select a voice for the copilot but not more. So I tried to get the checklist over the Menu and after that X-Plane chrashed. Log attached.
AT THE TAKE OFF it does not come out the VR in the pfd
domined39aniello wrote:
What kind of problem, please? Or please use skype j.a.romanov if useful.
Thanks Sir for answere. In approach disconnect autothrottle and pitch trim is crazy. Walk around continue
Trying this - can not get this issue. May be you can show me how this going via skype j.a.romanov, please?
Hi Sir new flight today work fine all. Problem is when disengage FD and Autothrottle. Thanks for answer best regards
Artijom wrote:
After the latest A320 update I had to realize that the copilot is not working properly anymore. Text messages are no longer displayed in the cockpit checklists.
Furthermore, some FlywithLua Scripst do not work properly.
What copilot you talk about?
JD-CPL-320
30 (edited by alain.bo 2020-08-30 16:33:35)
Big problem going to LXGB.
Flight plan is VAVIX UP181 BTZ UN10 NETUK UN857 PPN UN10 BAN UN857 MONTO UN864 PIMOS.
I'm currently arrinving at WP BAN.
First I defined a RNP27 approach.
LXGB_TWR comming online and defines RNP09 approach. There is no STAR here.
So I tried to set RNP09 and FMS erased LXGB airport from flight plan and also erased cruise altitude.
Impossible to set altitude, I don't know how to set LXGB again except doing INIT.
I also got one or two times this behavior with previous releases.
http://jardesign.org/forum/img/m/4152/t/p1eh035u7q1dl6n98fh8pu0hbe3.jpg
http://jardesign.org/forum/img/m/4152/t/p1eh036mmg26416drmn11c3c1jij5.jpg
Here is a list of errors for the JD A320 v3.6RC1
1. I use the Thrustmaster T.16000M, and so far I have been able to adjust the spoilers with the Throttle (2). This is no longer possible with the V3.6RC1. I can only change the position of the spoiler armed to disarmed. I can adjust the spoilers with the mouse. Please correction.
2. - if you use BSS soundpacks, please note what "Modules / Custom Module /" now is the same as "Custom Avionics /" folder
When I copy the files of the Optional FA announcements (Custom Avionics) into the directory "Modules / Custom Module /", I don't get a BSS sound. But if I copy the files from the Custom Avionics directory to plugins / sound2, then I also get the additional announcements. There is an error here.
3. The announcements of the checklists are missing, please add. I don't want to use the co-pilot.
greetings
Horst
JD A320
JD A330
Well so far I thought that there was going to be an EFB tablet on this update.
As always Jar Design A320 Great aircraft to fly, i have up-dated to version JD320-V3.6RC1  but i do have a slight problem when you taxi and turn in the air the Hdg Knob turns and makes clicking noise? is this a bug or can it be turned off
Many Thanks
Mike
Many Thanks
Mike
Ive asked about this but no answer
35 (edited by Steiner3D 2020-09-02 09:24:45)
http://jardesign.org/forum/img/m/10085/t/p1eh7238s7vmo123p13p41l11jcs3.jpgHi, when the aircraft loads, there's a nice and clean looking MCDU/FMC pop-out in a lighter grey colour (see attached image). If I've closed this MCDU, how do I bring it back up ? Clicking the cockpit MCDU(s) only pops up the darker and less readable ones.
36
Please assign command like jd/fmgs/CommandShowMcdu to show/hide this widget
Please assign command like jd/fmgs/CommandShowAm to show/hide Big Map and vertical profile
37
It's a pity we cannot set the FCDU altitude with the xplane commands AUTOPILOT ALTITUDE UP/DOWN
Horst
I use the TWCS one for that but that doesn't change anything and I can set the spoilers with the dedicated commands as shown below:
http://jardesign.org/forum/img/m/4152/t/p1ehejlqnk1ei12k410c42jbamj3.png
Thanks Sir JAR for update. Have a problem with TRIM when disconnect autothrottle on approach, MAC CATALINA version METAL
This issue happened to me today too, while I was approaching around 500 ft i disengaged the autpilot and started to approach but suddenly the pitch started to change randomly it went to positive 14 and straight away to negative Hope you will take a look at it just wanted to report it thanks! have a good day
40
Hi sir, Another bug which I found is that when I change the barometer to local qnh of 1014 it does take action in the PFD and it adjusts the setting properly but the writing of 1013 does not chance to 1014. Thanks a lot and great work
41
Hi sir, thanks for the update. I am currently running a320 latest version on xplane 11.50 RC3, and I found some issue down below:
1. When I was flying older a320 version 3.3 r3, the engine indicator in the central panel is spot on (if the small indicator set to 40%, then the n1 will not exceed that value. In the most recent version, I found that has changed and not linear anymore (when the indicator is 40% it will rock to 50-60% n1). And during takeoff I usually set to TO/GA. In the past,  TO/GA will be between 90-100% depending on my PERF setting. In the most recent version, my TO/GA value will not exceed 82-85%. Although I could still takeoff as usual, I just wondering if it is a bug or I think too much.
2. I found that the ATIS receiver will cause a CTD in the latest x-plane 11.50 RC3, and with the old model 3.3r3 it was fine. Please investigate this problem since getting updated weather from the sim is quite useful and important in takeoff and approach phase.
Otherwise, great update overall, especially the ground handling and load config!
I have a joystick with several buttons. I want to configure them for taxi lights, landing lights, beacon, strobe etc ... the aircraft does not respond to the configured commands. How to solve this?
XP 11.50 is now final and released.
Jardesign A320 can now made final for the use with XP 11.50, after the repair of some reported issues of course.
44
R1 is posted today. For this version FCU knobs may be operated with left/right mouse button and mousewheel.
45
Hi, on older versions there was an option on the MCDU menu to display a shortcuts toolbar which gave quick access to functions such as towing and fuel. I can no longer see that. Has it been removed?
Please read "WHAT NEW" part in the first topic.
Thanks a lot for this sir they work flawlessly now, For the FMC is there a possibility to add the feature of PLACE DISTANCE POINT? This would be very useful if it is actually added to the JARDESIGN A320 thanks a lot great update!
48
So is the New EFB Tablet going to be in the V4 or is it still planned for the final release of the V7
49
I had to reinstall my airplane because of the update. But now every time I try to load in the aircraft a second time(because the first time I opened it I wasn't able to but my serial key in)  I´m getting message which says: "Mac.xpl cannot get searched for virus because it isn't verified. if I press on open it pops on another time if I press on open again I instantly get kicked out of xplane. I´m on Mac btw so I really need help because I don't know what to do.
50
Please follow this instruction about usage with Catalina
http://jardesign.org/forum/viewtopic.ph … 110#p31110
