126
Re: XP11.50 JD330 v.4.1
chrischiozza wrote:
I have downloaded the latest version and installed into "aircraft" folder but it does not show up in the list of aircraft to select.?? I have done this a number of times but never seen this.
When you open aircraft folder (the one you placed into "aircraft") do you see the file xxx.acf amongst all files ?
if not you made a wrong installation …
Disregard
128 (edited by KAKUS11 2020-05-31 21:46:44)
has such a problem with the A330-200 jd when I start the plane myself with the engines not turned on, the plane does not keep my course.
Not three data entered flies straight after some time you can turn off the remote control car and lose height.
As it is flammable with the engines running, everything is fine.
Hi, I have a problem AP1 does not follow the waypoints when starting a plane with the engines off.
If I start with the engines running, there is no problem.
I am asking for help in solving the problem.
I just got it to work. I will try it out and let you know.
130
After take off when activating the AP1 or AP2 it does not hold the NAV. With my sim it goes into a climbing bank either left or right to the selected alt. the alt knob either when selecting OP Climb or Climb has no effect on the climb rate.
132
Next is when using my Saitek yoke and throttle setup when I set my slats to the "prop" and my flaps to "mixture" levers on moving the flaps its glitchy. Set to flaps 1 the lever is jumping from 0-full all the time. It is not an issue on my other airplanes I have.
133
Rudder fluttering still wild on this version.
134
This is what every screenshot of the 330 looks like, and when I try to stream it, it looks like this too
135
Nadal nie działa metar z active sky
136 (edited by KamilGo 2020-06-14 08:23:42)
Any idea why in Xplane 11.50 whit Vulkan i have that issue whit aircraft:
https://youtu.be/9G13U3vFzUQ
Whit OpenGL everything works normally.
137
Hi guys,
I have got problems when using V4.0.5 & BSS and XPRealistic and ASXP (latest beta). Has anyone out there got the same sound problems? Either there is a roaring wind sound or no sound-pretty funny ;-)
Happy landings
DLH067U
138
same here xp crash when i try to load the A330 &A320
139 (edited by flightime56 2020-06-23 05:49:58)
Downloaded vXP11.50 JD330 v405 and there are no engines? it is in v11.50b11 Vulkan
http://jardesign.org/forum/img/m/30/t/p1ebdvnehcvems21q2i175a1pa13.jpg
Problem resolved...  bad livery!
140 (edited by aliz 2020-07-04 17:53:39)
https://store.x-plane.org/JARDesign-A33 … p_409.html
Do the above sounds work with the beta or it needs the stable version? thanks
Yes, those sounds work but you have to make sure you download the latest version from the xplane store. It is version 3.0. Also make sure to copy + paste the xLua file along with BSS during installation or the sounds will not work.
142
When will we expect with tab in JD A330?  @J.A.Romanov
143
I love this A/C but it's still needs rework for the 11.50 ver.
I'm sure JARdes will fix but it schould be done properly because in this version (4.05) I cannot fly the airplane very stable.
- Baro change GNH -> STD button not working in 3D cockpit
- AP looses control from time to time and does not follow the route
- Ground Handling problems, APU or GPU not really stable when pushing buttons
- Fast Rudder flattering (FL/CTRL System page)
- Radio with no sound
- Very few FMC functions (many pages/knobs entries not simulated yet)
Thanks a lot.. I will report gain awhen I have some other points.
Keep working oin this beautiful aircraft!
144
Know why can't change autopilot speed,atltude qnh ?
145
J.A.Romanov
Hello i have several problems detected with the new version 405:
1.) Dome Lights are not working
2.) APU GEN no load indication, shows only 0A
3.) No screenshot and no videos are possible.
146
Hello, I'm using JAR A332 V4.05 and my current XP version is 11.41.
For some reason, when I load this plane, there is a CDU display on my lower left side and I can't remove it.
How can I close this screen?
Thanks in advance.
147 (edited by thommy24dd 2020-07-27 20:04:12)
Hello, does anyone have an Idea why preview pictures do not work anymore ?
Today when I did fly the plane with AP and I did turn the knob for heading the heading of the plane got changed and the plane followed the change but the value of the heading display was always the same!
Did anyone notice this behavior also?
I am still in X-plane 11.41...
Thommy
148 (edited by shdia 2020-07-31 09:20:59)
Hello Sir,
I have installed the update for Xplane 11 for version 11.50.
I still have the same problem...just after loading the aircraft, xplane just shut down.
I really don't know whatb to do...since 2 weeks i try fix with no success.
I have just native xplane plug-in that i have de-activated, but same thing.
Please help me....PAN PAN PAN
Hi Mr. Romanov,
thank you very much for your fine work. I just completed a flight vom KLAX to KSFO without any issues.
Everything worked as it should.
cheers
Bernd Schwarz
150
I'm using Vulkan. JARDesign A330 crashes on Vulkan, on desktop. X-Plane 11.5 crashes. When I select A330 the loading doesn't finish uploading and it crashes .
