Re: JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
Purchased the JARDesign A320 NEO today morning. Have got the FF320 since about 2 years and viòla ... what a nice bird...even under XP11.5b9- what FF can't support at the moment. I am delighted! Even got the BBS sound working. Amazing!
BUT what I have not got it how to close the cockpit door.
Read a lot in the forums or even tried to shut it like in zibo. In FF320 the door is always shut :-).
Have you any idea?  Sorry for that silly question.
Always safe landings,
DLH067U
DLH067U
Unlock the door on the panel left of the barking brake and close the door by hand. big_smile
53 (edited by DLH067U 2020-05-25 13:41:28)
Yeeesssss, so simple big_smile...omg..thanks mounirvanhill
54 (edited by Wangenheim 2020-05-30 09:05:18)
VBV01 wrote:
Message on Facebook from Blue Sky Star Simulations  today:
*** Update alert #2 ***
JAR A320 has been updated to V5.0
Completely new sound pack is 90% done and will be out some time later.
Currently it is only available for those who bought through BSS store via same original link provided, or in your download cabinet. XP.org will be updated day later as we need more testers on this one.
1.You will need to download clean version of A320 from JAR website (version 3.5) http://jardesign.org/forum/viewtopic.php?id=11840
2.Then you will need updated Main A320 JD CFM BSS pack V5.0, download, and follow installation instructions (same as before). IAE does not need to change, all changes are in main pack.
Fixes/updates
-Some volumes
-Vulkan compatibility
-Clicking noise bug fixed
Clicks in cockpit are back with BSS pack 5.0.
New workaround.
# FCU rotate ################################
type=3d
play=once_when_drf_change
filename=HDGclick.wav
#play_drf=jd/anim/fcu/alt
play_drf=sim/custom/xap/ind_baro_hpa
#play_drf=jd/anim/fcu/spd
#play_drf=jd/anim/fcu/hdg
#play_drf=jd/anim/fcu/vvi
x_position=0
y_position=2.14
z_position=-14.14
vol_int=2
vol_ext=0
Hello, I love the plane just a quick question are we ever going to get the calls for the cabin as the cabin ready message is always done but id love to add more realism by having to click the FWD or AFT cabin calls thanks!
I keep getting crashes due to the JD320 sound engine...
I have even tried it without the BSS pack, just the core JD320.
Log below,
thanks,
Dan
Thanks for the update for Vulkan. Please note the FCU knobs (V/S knob and HDG knob) are animated during A/P and thus are triggering the knob rotate sound effects which is highly annoying. The knobs should not be animated during A/P and only when physically manipulated by the user.
58
Since the installation mentioned  - make sure, that you use X-Plane 11.41-11.50, I thought I give this beta version a try on X-Plane 11.41 but unfortunately some of the knobs & switches no longer work, unable to rotate some of the knobs eg. ILS/NAV/PLAN and the heating knobs for example.
However, FPS has improved but I am unable to use this version due to the above.
@ekfpang The beta is for 11.50 (Vulkan API Graphics Engine Driver) and up. Youre mixing apples and oranges.
Its because JARs damn FCU knobs rotate during heading and altitude changes in A/P mode!!!!!!!!! So the BSS sounds are triggering constantly during these instances. Its JARs problem, not BSSs. I commented on this to JAR and its not responded to. It was THEIR bug all along!!! When he was saying get BSS to help you it was always JARs problem!!!!!!
Fixes/updates
-Some volumes
New workaround.
type=3d
x_position=0
y_position=2.14
z_position=-14.14
vol_int=2
vol_ext=0
61
@hardfloor, I understand but the installation mentioned "make sure, that you use X-Plane 11.41-11.50" hence why I tried it.
Dear Romanov
How do you deactivate this unnecessary reflection in the cockpit pane that is very annoying
gigabenga wrote:
Dear Romanov
Click on center PFD
64 (edited by dron420 2020-06-27 11:59:39)
gigabenga wrote:
Dear Romanov
This is for instruments glass. In upcomming version main windows reflection switch will have separate click spot.
domined39aniello wrote:
gigabenga wrote:
Dear Romanov
Click on center PFD
Apparently you can not read ??? not INSTRUMENTS special COCKPIT windows. Don't answer if you can't read. thank you
66 (edited by euroking2018 2020-06-28 10:31:19)
Win 10 1909 (Build 18363.900)
X - Plane 11.41
GeForce Vulkan Game Ready Driver 451.48
DirectX 12
No change, X-Plane 11.41 compatible ?
The checklists are read very slowly.
What is the cause?
67 (edited by Binary11 2020-06-29 21:19:29)
I'm using 11.50 beta 11 since yesterday and noticed that I'm not able to click most of the buttons in the cockpit. The page says it's compatible with version 11.50 so why isn't it working? Did I something wrong or is it a known issue with the current version?
Edit: Restarting my PC fixed it.
68
Have you install the NVidia GeForce Vulkan 1.2 driver 442.81 ?
69 (edited by euroking2018 2020-07-08 13:23:02)
Now everything works fein.
The adjustable pilot seats are very cool. smile
thanks.
X - Plane 11.41
DirectX 12
What is the cause?
How did you fix the checklist problem?
71 (edited by kjell.norheim 2020-07-26 09:49:16)
I downloaded the the Betaversion 3,5(11.50), but its not possible to activate it with the serialcode I have from an earlier version. Anything I've  missed here? And also get this message (ERROR: a320 system (SASL) plugin not activated). Have read all I can find to solve this, but looks like I need some help. If anyone knows a solution.
72 (edited by mits75 2020-08-07 08:12:14)
Здравствуйте. Такая же проблема как и у предыдущего. JD320 3.5 не воспринимает ключ от 3.4. Что делаем не так? Самолёт куплен месяц назад.
73
Guys. Please open the ticket by our website here.
http://www.jardesign.org/ticket/support_view.php
74
320 or 330 engine dont start without shift E or starting from xplane.
No fuel flow, stay to 0.
How can I insert a flight plan? Something changed since 3.2 version and I cannot figure it out. I generated a flighplan on SimBrief and just want to load it. I put it in INIT and then nothing happens. What am I doing wrong?
Thx
