Topic: JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
So.. a320 for X-Plane 11.50 version 3.5 public beta
This version get new/updated FMGS, like JD330
WHAT NEW:
b2:
+ X-Plane 11.50 compatible
+ X-Plane 11.41 compatible
To be clear - this is not new version with new features, but just updated to be compatible with X-Plane 11.50 with Metal/Vulcan
JD320 Download link:
http://jardesign.org/a320/download/inst … 50_352.zip
Updated CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
  - Please not mix files with other version.
  - make sure, that you use X-Plane 11.41-11.50
    (make sure you don't use nonEnglish symbols in aircraft's installation path)
  - start X-Plane 64 bit and open a320, activation window will pop up
  - enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
(create it if need)
Thank you!!!!
Re: JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
reserved
reserved
Great support, thank you, will test it when 11.50b3 arrives
Have a nice easter weekend, stay healthy
X-Life Deluxe
GHD
FMCAR
JD320
Thank you so much smile
6 (edited by pistonbroadcasting 2020-04-09 18:20:25)
thanks for the quick update.
When i get into the aircraft and i hit GPU to get external power I get the following error  'pipeline must not be null ptr'. This only happens when Vulkan is enabled.
Any idea why?
Any idea why?
I have the problem too
if you start the plane with the APU its fine. So you can use the plane in Vulkan, but you can't use the GPU
Getting " pipeline must not be null ptr" right when trying to load A320 neo and hard x-plane crash. Running 11.50b2 with AMD card and Vulkan.
The "pipeline must not be null ptr" error appears directly after activating the GPU or other ground handling activities. The same while trying to set the fuel (because the fuel truck is active too).
Log attached.
Log attached.
The new beta update from XPlane is fixing the bug!
Thanks for the update.
But honestly - why is it the only plane so taxing (fps etc) even with Vulcan - you do need to do something about this?
Beta 3 is out now, so the crashes should not occur anymore
Beta 3
    Fixed crash at launch with Linux + Vulkan.
    Fixed null pipeline with third party aircraft using custom lights.
Hi Sir thank for update. On METAL very poor FPS with this version
15 (edited by legista 2020-04-11 19:40:34)
With me it's just the opposite - FPS have increased. And memory usage is lower.
Also, i like toolbar in this version is VISIBLE by default and i don't have to turn it on every time.
Hi there,
thank you for the update to v3.5b2. The plane works very well, only the announcements of the checklists are spoken far too slowly. Please change this with the next update.
JD A320
JD A330
http://jardesign.org/forum/img/m/7937/t/p1e5n3p94j86m1gg81ere15ut1kkr3.jpg
I have the old menu button 'M' back - I wonder why? The a330 XP11.50 update still shows the usual green GPU etc. Did something go wrong?? It's odd to see this again after all this time. Thanks.
See the settingspage in the MCDU. You can turn it off there.
Cor
Ah, I'll look. Thanks. However, the M button keeps reappearing of its own accord. I had the onscreen green GPU earlier.. in the middle of preparing the a/c, the 'M' is back again, of its own accord (haven't even been in to the FMC yet).
Hi there,
I can't seem to get the BSS soundpack to work with this version. Do you know a way I can fix this issue. Thanks
21 (edited by WoDi 2020-04-14 19:39:28)
Since JarDesign is the only avionics company that has updated its aircraft for the 11.50b, it was close for me to activate the A320 neo.
So first of all I updated the X-Plane 11 to 11.50b3. I don't want to say anything about that here...
I started the A320 neo, did everything that is necessary with such a bus and off we went. After the take off the landing gear was put in and then the AP was activated. This was also confirmed by the callout, but it has no effect. In one word: AP is not working. Neither with 11.50 nor with 11.41.
Now I've been doing all kinds of things for ages that you can do in such a case: The default Cessna loaded, then the A320 neo. Reinstalled and updated the A320 neo. Etc., etc. ...
The default planes have no problems with the AP.
Do you have an idea what else I could do?
Translated with www.DeepL.com/Translator (free version)
Edit: It´s the same with A330.
Thank you for this update but I have the problem, that the ND, Pdf and the MCDU are flickering. Are there any known solutions for this problem?
http://jardesign.org/forum/img/m/9704/t/p1e64emi3c5np1snjbhkvd61n8n3.jpg
Anybody have a question about that?
I had this question to Eugeniy. The answer was that it converts from inHG to hPa. This issue is migrated from old versions. I don't know why it could not be as it should:(
I hope someday it will also fixed.
JD team doing their best to improve their products. They introduced first A320 for XP11. Now they first updated their aircraft for 11.50.
Big thanks for their job. Thumb UP!
25 (edited by johnths2 2020-04-18 08:06:33)
A had a problem with auto throttle.
On a flight after level-off, the auto pilot swiches off, reason??
After swiching the auto pilot back on, the auto throttle won't hold his speed setting.
It made no difference what i do, the auto throttle won't hold speed.
Throttle handel setting was in the "CL" position, the auto throttle light was green, speed setting on 200 knots.
Flaps up, no spoilers, gears up.
Is this a bug or is there a explanation for this?
I run XP 11.50b4.
