Re: JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
Thanks for the install. Working good on 11.50 rev4. However the only issue is regenerating icons for the A320 causes Plane to crash.
JARDesign Group Board → Download, Updates → JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
BBS sounds with JAR
I have found that repairing the BSS for the competitor works using 2 files from this JAR beta, because BSS uses the JAR soundplayer.
Get win.xpl and openal32.dll from jara320\plguins\sound3d
and copy these files to the plugins\BSS folder (make copies of the original files before)
Maybe this works for the BSS for JAR pack, too. I can't check, because i dont have BSS for the JD320.
Because its a known bug of XP11.50 (see the release notes of Xp11.50) and has nothing to do with the JD320
servlan wrote:Thanks for the install. Working good on 11.50 rev4. However the only issue is regenerating icons for the A320 causes Plane to crash.
Thanks. Seems strange that the Zibo 737 works with the same bug and yet the icons work fine.
BBS sounds with JAR
and copy these files to the plugins\BSS folder (make copies of the original files before)Maybe this works for the BSS for JAR pack, too. I can't check, because i dont have BSS for the JD320.
I did it several days ago. It is working workaround. Even it is a fix and not a workaround.
A had a problem with auto throttle.
On a flight after level-off, the auto pilot swiches off, reason??
After swiching the auto pilot back on, the auto throttle won't hold his speed setting.
It made no difference what i do, the auto throttle won't hold speed.Throttle handel setting was in the "CL" position, the auto throttle light was green, speed setting on 200 knots.
Flaps up, no spoilers, gears up.Is this a bug or is there a explanation for this?
I run XP 11.50b4.
Try to turn of A/T by pressing on its button on FCU and then move levers to TO/GA and then back to CL. This will engage A/T back to speed mode.
BBS sounds with JAR
Hi Sir I confirm with this method BSS Sound working fine X-Plane 11.50 beta4
Clicking sound in cockpit
Anybody find they have a fast clicking sound in the cockpit? I have BSS sound pack installed. Clicking sound disappears in outside view. Running 11.50 OpenGL.
Workaround:
http://jardesign.org/forum/viewtopic.ph … 137#p30137
Great thanks for the workaround link
Thanks, that worked for me.
Question about the FMC.
How can i delete a programmed flightplan out of the FMC whitout restarting a new flight?
Go to INIT page and put new destination/arrival airports to upper right corner button. This will reset flight plan.
hello, the plugin A320 JAR BSS CFM v4 is not compatible with JD320 Airliner beta ver 3.5 WIN / MAC 64 bit (X-Plane 11.50), because there are now three sound1d, sound2d, sound3d directories.thanks for information
sorry, I had not read the tip SandyLee. copying the two files win.xpl and openal32.dll from jara320 \ plguins \ sound3d into the sound3d directory was very helpful. now the sound works again.
So.. a320 for X-Plane 11.50 version 3.5 public beta
This version get new/updated FMGS, like JD330WHAT NEW:
b2:
+ X-Plane 11.50 compatibleTo be clear - this is not new version with new features, but just updated to be compatible with X-Plane 11.50 with Metal/Vulcan
JD320 Download link:
http://jardesign.org/a320/download/inst … 50_352.zipUpdated CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zipHOW TO INSTALL:
- Please not mix files with other version.
- make sure, that you use X-Plane 11.41-11.50
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
- activation works well with both MAC/WIN 64 bitIf activation window not appear, there is 3 reasons may be for this -
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.UPDATE YOU NAV DATA WITH FRESH CYCLE (if needed)
(create it if need)Thank you!!!!
The aircraft is crashing for me - 5th time today! Attached is the log.
Please help.
>>Maybe a problem on 3.5, I often get THR CLB while still on RW.
No worries, it's my fault, problem entering THR ACC altitude.
Hello, good afternoon, I am writing to you because some important parts of the cabin are inoperative in version 3.5B2 of xplane 11.50, do you know why? I expect an answer as soon as possible.
Thanks and best regards, Jacobo.
Using 11.50b6 and flying nicely. Does anyone have a good sensitivity profile for the A320. It's very sensitive on the roll and Pitch. And also the yaw taxiing is very touchy, barely move the rudder pedals and the plane jerks to that direction. Just looking for a better way to hand fly and taxi this plane. Thanks.
Take a look at your response curves in Xp11 joystick settings.It is a little trial and error to get it just right for your system. ![]()
Thank you Steven. I will do that. Was just wondering if someone had a saved profile. But I'll start changing it around a bit to get it more stable.
Dave
since this not a new version with new features and I do not want to run 11.50betax, I decided to stay at the last version!
I am looking forward for the new big update!
about one month passing
i hope v4 A320 is coming
i can't wait
even keep everyday to look at news
hope it will coming soon
Message on Facebook from Blue Sky Star Simulations today:
*** Update alert #2 ***
JAR A320 has been updated to V5.0
Completely new sound pack is 90% done and will be out some time later.
Currently it is only available for those who bought through BSS store via same original link provided, or in your download cabinet. XP.org will be updated day later as we need more testers on this one.
1.You will need to download clean version of A320 from JAR website (version 3.5) http://jardesign.org/forum/viewtopic.php?id=11840
2.Then you will need updated Main A320 JD CFM BSS pack V5.0, download, and follow installation instructions (same as before). IAE does not need to change, all changes are in main pack.
Fixes/updates
-Some volumes
-Vulkan compatibility
-Clicking noise bug fixed
I read through most of the posts on this thread, but havent find anybody who mentioned having the same problem as me. Before, i was running the a320 at 40-50fps in high density areas with high settings on my medium to high end pc, but with this version my fps dropped to 25-30, in the same scenario. After troubleshooting, I found that the reason for that was the Aircraft FMGS Plugin. Disabling it shut off the FMGS, the Navigation Display and increased my fps from 28 to 44 again. Using vulkan and Im able to run beefy aircrafts with detailed scenery, but the FMGS plugin is taking so much performance. I installed it correctly and havent had that issue with versions before, anybody know if this is a known bug or am I doing something wrong?
