Re: XP11.50 JD330 v.4.1
many thanks for the fast 11.5x version!
though I get very low framerate inside the cockpit, 10fps and lower, on the outside it's all fine. It's a behaviour I only see with other planes when they use librain.
It's the same for both types, 332 and 332 FPS boost.
(I have the bare installation of XP, with GroundHandling missing, but it makes no difference if it's there)
My set up is a MacMini 10.14.6 with an eGPU, log is attached. -> ah, how can I attach a log file? it seems to only let me add images.
Thanks! much aprechiated
Luke
I had the exact same problem! But after updating to version 11.50b2, my FPS came back to normal. Try to do the same.
