Topic: JD320 Airliner beta ver 3.5 WIN/MAC 64 bit (X-Plane 11.50)
So.. a320 for X-Plane 11.50 version 3.5 public beta
This version get new/updated FMGS, like JD330
WHAT NEW:
b2:
+ X-Plane 11.50 compatible
+ X-Plane 11.41 compatible
To be clear - this is not new version with new features, but just updated to be compatible with X-Plane 11.50 with Metal/Vulcan
JD320 Download link:
http://jardesign.org/a320/download/inst … 50_352.zip
Updated CoPilot Download link:
http://jardesign.org/copilotdownload/JD-CPL-320.zip
- Please not mix files with other version.
- make sure, that you use X-Plane 11.41-11.50
(make sure you don't use nonEnglish symbols in aircraft's installation path)
- start X-Plane 64 bit and open a320, activation window will pop up
- enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via X-Plane menu
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.
(create it if need)
Thank you!!!!
