151
Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
Is Lower Ecam Status page available in this version ?
152 (edited by rpvflyer 2020-01-03 23:20:38)
Hello I’m having a problem with updating my A320 aircraft. I’m presently running xplane 11.41. Is this version supported? I haven’t flown the A320 in a while... Last night I downloaded the 3.34 update from the forum cause it said my 3.3 wasn’t compatible. I loaded up the new 3.34 and got to the activation window. Activation goes thru and I reload the craft and all I get is a black screen. I can’t move around or go to other views. I can load other planes fine if I switch. However if I try to load the A320 and it’s just black screen. I tried reinstalling a fresh 3.34 copy and still same thing as first time I had added liveries and my BSS pack. Not sure what’s wrong can someone help please?
Ps experimental flight model is off
153
Please add the log.txt file from your x-plane folder.
It started working after a few restarts. if it happens again will post the log file. thx
155
Hi what can i do i love that Airplane but i have sometimes a Problem with overspeed
Copilot say we Need drag i make Speedbrake but Nothing works … what can i do ist the old Version of a330 .. ?
156
i Show u now screenshot About overspeed … Problem with jardesign a330 i became Always Problem with overspeed….
i cannot controll my Speed thats a big Problem pls help … !!!
157 (edited by Makcimus 2020-01-21 11:33:04)
Всем привет.
Написал в поддержку BSS по поводу непрерывных кликов.
Ответа нет увы!(
Hi everyone.
Wrote in support of BSS about continuous clicks.
Alas no answer!(
System: Core i9 11900F ~ 5,2Ghz , 32Gb DDR4 3200MHz, NVidia RTX3070Ti 8Gb, W10Pro. 64 bits, SSD 512Gb, HDD 4Tb
Monitor: Samsung SyncMaster S27A650D (1920x1080)
joystick: TrustMaster T.Flight Xotas X
Sim.: X-plane 11.55r1
158 (edited by dron420 2020-01-21 12:15:37)
Makcimus wrote:
Всем привет.
Ответа нет увы!(
Hi everyone.
Alas no answer!(
У нас на Фэйсбуке решение описано.
159 (edited by Makcimus 2020-01-21 14:40:15)
Я не нашел решения на фейсбуке, но тут на форуме, в соседней ветке, временное решение нашел.
Если Вы имеете ввиду какой-то другой способ, иной от описанного тут на форуме, то я хотел бы с ним ознакомиться.
Я как бы написал, что ребята из BSS не отвечают на запрос и это проблема!!!
Чем больше людей им напишет тем лучше, я надеюсь)
Скажите пожалуйста, как решается проблема отсутствия METAR информации на панели DCDU?
О том, что Вам известно о проблеме я в курсе, спасибо facebook, а вот как её решить не удаляя GIZMO я не нашел.
У меня стоят аддоны работающие с этим плагином и удаление этого плагина для меня неприемлемое решение.
Спасибо!
160 (edited by Makcimus 2020-01-22 18:14:55)
Мной было найдено решение для устранения ошибки получения METAR данных на панели DCDU вызванное конфликтом с плагином GIZMO.
Для этого необходимо выполнить следующие действия:
1. Скачать обновлённую библиотеку
2. Скопировать новый файл библиотеки в директорию с заменой:
"папка X-Plane 11\Resources\plugins\Gizmo64.plugin\64\ "
!!!Перед копированием не забывайте сохранить оригинальный файл!!!
Приятных полётов!
I found a solution to eliminate the error in receiving METAR data on the DCDU panel caused by a conflict with the GIZMO plugin.
To do this, follow these steps:
1. Download attached libcurl.zip file, unZIP it, you will get libcurl.dll (the updated library file)
2. Copy libcurl.dll file to the directory with the replacement:
"X-Plane 11 folder\Resources\plugins\Gizmo64.plugin\64\"
!!!Before copying, do not forget to save the original file!!!
Have a nice flight!
https://sun9-55.userapi.com/c200820/v200820667/469e3/s4oAip0Asks.jpg
161
ThaT FLASHING RED "RENDERING WARNING" IS EXTREMELY ANNOYING! i HAVE REDUCED EVERYTHING TO GROUND ZERO (WHICH I DO NOT HAVE TO DO ON ANY OTHER PLANES) AND IT STILL FLICKERS DESPITE 30+ FPM. GET RID OF THAt thing...please.
162
how do you implement the MCDU?  I cannot get a Progress Report because it reads "NOT IMPLEMENTED".
163 (edited by jcdp 2020-01-27 16:44:26)
in MCDU "settings" put message on "off" .
I suggest you watch all proposed tutorial videos … you will learn what to enter in MCDU and how to fly this airbus .
Hi. The A320 neo gives me problems. The "QNH" is flashing when the flight plan is presented at the FMC. Also midway the altitude is set to zero and I can't control the plane. And several more problems. I was removing the plugins in case any caused problems but it is not. If someone could help me I would appreciate it. Sorry for the translation, it's for the google translator.
165
I have the latest version of x-plane 11.
166
Activation issue resolved. You can install / update JARDesign 320 and 330 again. The problem was related to the failure of the SASL activation server. We apologize for the inconvenience.
167
Здравствуйте, не могу назначить на джойстик кнопки включить или выключить  свет( taxi, проблесковые маяки и т.д).
168 (edited by jacobocanarias 2020-02-05 15:05:16)
hello good afternoon, when does the jardesign a320 for the xplane version of 11.40 come out?
We know that laminar has sent developers a beta version with vulkan, I would like to know if you have tried and if you plan to release an update with vulkan?
Pharmacie populaire www.viagrasansordonnancefr.com toxicose du medicament
169
The agreement with LR does not allow us to disclose any details of tested versions (Include v.11.50 for now) of X-Plane what not yet in "public". Sorry.
170
I read in X-plane forum this
Edited October 31, 2019 by Dron420
"Good day, Captains.
I am pleased to inform you that a future version of the A320neo JARDesign will contain custom EFB whith support of the AviTab, of course if plugin is installed on your simulator. I thank Folko for help with integration."
Please tell me when come this version out, or I am somethnigs missed.
171
I have not understood well. Do I have to reinstall the A320 and A330?
If this is so, I will not buy you a plane or any complement. Thank you.
172
What do you mean by reinstall?
It is true. We are working on it, so I hope soon.
https://a.radikal.ru/a01/2002/15/35af85877d9e.png
174 (edited by zebaniz 2020-02-07 12:02:56)
I have bought and use all JD 320, JD 330, X-LIFE AND FMCAR. All very well and very satisfied. However, it would be great if you add the ability to record on planes (like Toliss and FF A320 Ultimate).
175 (edited by luyijie12 2020-02-07 16:23:53)
Activation being 'please wait'.What happened?What's the solution? l just bought it.
