Tested the v3.3r2
Still a small lack of power when reaching targeted FL, even if it is the OPT FL (Optimum Flight Level)
Script seems to be blocked so it can't help anymore.
For the while ... if some bugs are fixed (where is the changelog ?) , the plane needs some more improvement. At end of several flight consumption is less than predicted, meanings engines didn't furnished enough thrust. Use Simbrief to compute fuel burning. Assumed to be a reliable flight planner.
Flex temperature, v1, vr, v2 are also overestimated. I use Take Off performance calculator, and the natural rotate of the nose is coming more or less as its predicted vr.
When using the auto v1, vr, v2 I need an excessive push down effort on stick to maintain contact with ground.
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
