Topic: XP11.41 JD330 v.3.3 r1, r2, r..
This is next public version of a330 for X-Plane 11.
What new:
r1:
+ separate throttle control add (with hardware or incockpit manipulators)
+ FADEC module reworked
+ A/THR modes / indication reworked
+ Thrust modes / indication reworked
+ AP modes fixed
+ XP 11.40 compatible
+ macOS Catalina compatible
r2: 220120
+ "lost speed" at hi CRZ FL bug fixed
+ minor bugs fixed
Download link:
http://jardesign.org/a330/download/inst … 30XP11.zip
For macOS Catalina users - please follow instruction:
http://jardesign.org/forum/viewtopic.php?pid=31110
Download link to updated CoPilot version:
http://jardesign.org/copilotdownload/JD-CPL-330.zip
Download link to updated Ground Handling plugin to be well-compatible with XP11
http://jardesign.org/gndserv/download/GHDxp11.zip
In the case of wrong voice recognition setup crash on loading stage may happen. Please be ready to contact JAR via skype j.a.romanov to demonstrate how this going and make real fix for this by our crew.
- be sure, that you use X-Plane 11.35-11.40
- copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin (use link above). It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
- enter your serial key (use exist serial from "JD330 for X-Plane 11"), click NEXT and after a successful activation reopen aircraft via X-Plane menu
- One of your installed X-Plane plugin (like SeaTraffic) can block activation windows. You can temporary remove your plugins one-by-one and check is activation window appear. Another (faster) way you can use - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330.
(create it if need)
If you want to test how failures system work, you need use DatarefEditor plugin and enter "jd/bugs/" there. You will get small number of datarefs what may generate faults - APU Fire, as example, if you change value from 0 to 1.
- you may post you opinion about this version, post what you like/unlike
- please attach your log.txt if Crash happen.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
This is FREE update for users who own "JD330 for X-Plane 11" product.
