Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
(Этот плагин последней версии 3.4 совместим с Mac OS Catalina, выпущенной вчера, до того, как я обновлюсь?)
domined39aniello - care to add a bit more information?! What problem have you encountered?
Hi Sir problema with file mac.xpl and when start A320 3.4R2 don't show a start and problem whit ECAM ND and PFD and button don't click.Thans for answer
Этого никто не знает пока.
Hi Sir can you explain me if A320 3.4r2 work on Catalina? Best regard
installed new version in X-Plane 11,Ver 11.40b8.(x-plane 11/aircraft)
Now i can't find the a320 on the airplane list
Is it, because that's a beta? is there a workaround, just to make the icon visible, so I can try, if it works well with this beta?
Sorry, my fault, I used the Mac files for a windows version
Now it works
107
is there anyone else who cannot connect the JD aircraft with the new Xpilot? no radios are working
108
plane's radio seems doesn t work with last x-pliot for vatsim.
blue sky
I'm on the same boat with Radios not working on XPilot.
Xswiftplugin works but you need an additional stand alone software and swift is overy complicated.
I really like Xpilot.  By the way, it does not work on the 220 neither
110
Guys. I have conversation with XPilot developer today and after some reserch we have find what happened. You can expect fix for this soon.
111
new version just fix for vatsim users .
NO fix for lights NO fix for FMC (this very important for online users) ! thank you !
112 (edited by euroking2018 2019-10-27 15:39:16)
The X Plane 11.40b9 and the JD A320 ver.3.4R3 work fine.
X Plane 11.40 r1 works well too.
cheers  smile
113
Still can't get my FMS Database to update to new version, I use navigraph and x-plane 11.36 all my other aircraft FMS Database updated fine but I can't get the JD320 ver 3.4 r3 to update. However the radios are now working with x pilot and vatsim.
Appreciate any ideas....Cheers!
114
Just check that you extract data base in correct place:
X:\X-Plane 11\Custom Data\GNS430\navdata
https://c.radikal.ru/c35/1910/59/09663a0f9bc5.jpg
115
when i load into the plane with engines started i have no wings and just the red engine covers but the rest is there
116
Hi Jar,
I´m on JD A320 3.4r2  with XP 11.36 and miss the command "You are close to the top of decent" from the "old version".
After some flights with the A320 I think the top of descent from MCDU  is set too late. I have sink rates from more than 35 and I think that's a little bit too much.
117
What i would like to see changed/fixed in next versions
a) APU shut down time, AFAIK from watching many Airbus video, the APU needs some time before it shuts down incl. the APU Gen
b) i have set QNH 988 and the PFD showed 987, for 987 it was 987 too, for 989 it was 989, but 988 is wrong.
and what i am not sure if this is different for NEO,
should the aircraft move with engine idle or not ?
X-Life Deluxe
GHD
FMCAR
JD320
118
@dron420
could you guide what should we do when atc says direct to a point (that isnt in our plan) but when we type in dct page it says missed data? its really bad when u fly online
119
Currently flying this version, and today the CRZ FL/ Temp value went from desired flight level to 000. Tried several times but still ends up at 000/00.
Any idea what it is?
Rune
120 (edited by vahooli 2019-11-06 21:07:25)
vahooli wrote:
@dron420
see attach , againonline atc and missed data error while direct ot a point isnt in flight plan !
121 (edited by Paulooo 2019-11-09 12:00:07)
It would be great if they updated the aircraft controls. This is something that bothers me a lot and not only me but also other people. If during landing ILS you turn off and give a touch to control the landing the aircraft swings a lot, sometimes even leaving the course of the runway forcing you to redo the approach. Other than that it is perfect, if the developer devotes himself to leaving the aircraft with more precise control I guarantee that a lot of people will return to the voala as well as me, I ended up buying another A320 that ends with my FPS, but the controls are very accurate. Thanks for your attention and it's just an improvement tip for the aircraft I hope you understand, I think she's the most beautiful for XP
122
unfortunately we buy this plane without any support !
123 (edited by dron420 2019-11-11 09:53:00)
Mmm. Interesting statement.
Just intersting - Is this an attempt to provoke?
124
Dear JAR Team, could anyone tell me what the problem is?
Starting with A320 at EDDP, everthing looks well and than after round about 30 minutes the wings and some more looks like this! I use JD320-V3.4R1, X-Plane 11.40 (latest update, no beta). Don't know what it is and it comes with all liveries I use.
Thx for your ideas!
125
ON 3.4r3
posting a few issues that, no matter what, they seam are solved.
-1 T/D too late!!! This has been posted many many times since 2018 and still no changes!!!!!
-2 flight model....3.2 worked great and since 3.3 it got shit the plane struggles to follow some hard turns in the flightplan and it goes out of route.
-3 cockpit light too low (internal light Dome) also FLOOD LT knob doesn't work.
-4 taxi... needed way too power to taxi.
-5 precision of controls
-6 reset fuel consumption after a flight, before starting the new one. It should be automatic every time that there is an engine start but in the Jar plane is not.
-6 as @vahooli wrote, impossible to do a "direct to" a point that is not on the flight plan.
Can you do something about it or will it remains always like this??
