Re: XP11.35 JD330 v.3.2 r4
According to my experience I have seen very poor lacking many things
how install etops in FMC
Hello
I would like to know what is the latest version of the JD330, because I have the JD330 V3.2B4 version dated June 2019 and I just saw that there is a n version in V3.2R2 ...
What is the most recent?
Thank you and have a good flight
The METAR problem suddenly happened again.
I checked it against weather engine, what engine used, X-plane native, or NOAA weather, it makes no differences.
I checked HTTPS site against SSL tools which reports GoDaddy is not the most trusted certification authority. By the way, neither Microsoft nor Mozilla Firefox bargained when I downloaded directly the files whose URL were given by the log.txt file.
The lone thing I remember to have done differently was to ask FMS to compute the route by itself using the request right but on FMS.
I ll try re installation to check if there is somewhere a flag which has been set and not reset !
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
ouistiti06 wrote:
Hello
Yes there is a mismatch as when I downloaded and installed the zip which was supposed to deliver 3.2r1  it was writtent 3.2r2 on the plate inside the cockpit ...
VID 566478
VAT 1400805
but what is the latest version ?
JD330 V3.2R1 ?
JD330 V3.2R2 ?
And the version JD330 V3.2B4 ?
Includes nothing more ....
cordially
107
I think it is V3.2r1, version given in ./plugins/330/News/260719.txt
The plate indicates JD330 V3.2R2 but it is also a txt file (plate.txt) and I really don't know if it is more reliable than information given on the forum.
About V3.2B4 it is always a previous version than V3.2R1  as B i for beta aka in tests, when R means Release so much more achieved version than a Buggy Beta !
You may have
V3.2B1
V3.2B4
V3.2B14
before being able to use
V3.2R1
VID 566478
VAT 1400805
108
I just Purchased this airplane right now.
How can I know What version it is or how can I know that is the last version and I dont have to do any update in addition?
Thanks,
Download it from the first post of this thread. Its the last version.
110
Shortly after takeoff T/O config warnings appear and sim crashes... what am I doing wrong?
111
I too receive all types of warning when I start lifting off the ground A330 Jar. Flaps....too low....landing gear......all types of warnings...then it all stops about 30 seconds into flight. Everything for takeoff is set correctly. Dont know why this is happening.
How many plugins are you loaded?
Disable some Ground Traffic plugins and test.
113
JD330 causes x-plane crash when trying to load the A330, due to the SASL plugin. What do i do?
114 (edited by mert4ever 2019-10-23 10:09:48)
Why does the RAIN WINDOW seem constantly closed?
It looks like this when I open the RAIN WINDOW
http://jardesign.org/forum/img/m/9260/t/p1dns1f4q91a8p1p0f1pfqug11gq03.png
115
Need just contact with www.support.jardesign.org with log.txt file (saved just after crash happen)
116
my engine is not starting this dont happen to older version
117 (edited by nkmsw8 2019-10-29 02:41:36)
I fixed the windshield issue with the updated version of the GND however I'm still having an issue with the error on the lower left of the pic. It says "VA" plugin error. How can i fix this? Thanks.
118
Did you find the fix for your problem?
119 (edited by F1le 2019-10-30 16:55:05)
Those plugin errors quite often appear when you have TOO much plugins installed... Go to your scenery and remove some Custom Scenery/AnyScenery/plugins/GroundTraffic folders.
Remove some and test.
120 (edited by mrkfire 2019-11-01 02:11:35)
Does anyone have a fix for the rain window issue?
121
In my case, set your A330 rain window then reopen X-plane11 will fix this issue.
122
Hey, when updating the FMC Flightplan during flight X-Plane crashes. Could you fix that?
respected developer@J.R
actually lot of confusion going on in xplane org regarding the latest version so i an confused
what is the latest ver because i am having 3.2r4 is it latest or some thing else
thanku,help is really appreciated
thanku
124
thanku
Hi  Sandeepkr
Normally it is 3.2r3 … (r4 should not exist)
What is written in the "plate text" file in your aircraft folder . There you should find the answer to your question .
respected@ jdcp member
thanks for the reply.but when i download frm http://jardesign.org/a330/ the ver said 3.2r4
anyway thanks for reply
