Re: JD320 Airliner ver 3.4 r3 WIN/MAC 64 bit (X-Plane 11.35-11.41)
Not getting the side bar menu with the latest update, GPU Refuel etc ?
You may use MCDU MENU for all this things
53 (edited by thommy24dd 2019-08-15 16:24:28)
can someone tell me what happend with the engines?  https://i.gyazo.com/4d31624c80a94c75f9ed60c78b8482f2.jpg
It looks like if there is engine inside engine!? MCDU stays black after "hot start" v3.4r2
May be some aircraft plugins was not loaded well. You may attach log.txt just after aircraft will load. Or contact www.support.jardesign.org with log.txt
55 (edited by F1le 2019-08-20 20:53:57)
So far ...
1/ Is there any possibility I can have Heading selected and the same time I press autopilot and have heading and dot confirmed autopilot taking LNAV? Doing something wrong?
2/ So often when doing some DIRECT to get direct to new point the Approach is vanishing (from LIRJ25 - which was programmed as RNAV, suddelny is just LIRJ and no programmed approach)... I have to reprogram it again and again....Anybody got same bugs?
3/ Often programmed everything on LNAV and VNAV and despite lowered altitude set, the airplane does not want to go lower. Need to descend manually using V/S.
By itself I got Toliss & FF and JAR 320&330. This plane JD320 is not bad at all (I'd say I really like it flying - seriously), but the amount of bugs imo is killing the fun vs competitors. Everytime I have to worry if the plane will go VNAV path to descend despite altimiter is correcly set so the plane should start lowering. Sometimes the MCDU will clean due to unknown reasons (for example page #2 in Init (had it couple times I had to change the plane as I wasn't able to program it all the time it was cleaning this page and VNAV profile was wiped out from MCDU). Sometimes I am not able to turn VNAV due to unknown reasons.
I have a mixed Manual heading and dot signalizing VNAV on (???????????)
(Heading selected with dot (for example 150*) - but the plane is using heading not the heading from MCDU.)
BTW : Does the plane simulate engine iceing/wing iceing?
With X Plane 11.36 and NVidia Driver 436.15 from 27.08.2019 work JD 320 V. 3.4 properly.
greetings.
martin smile
Hey
Ive just bought this plane. I have a problem after i installed Reshade, my autopilot dont work anymore. It worked before ive installed reshade. How can i fix this?
58
Hello JAR, can anybody tell me what happened with the wings? X-Plane 11.35 and the livery is from the forum.
59
Try to erase easyjet livery and install fresh livery again.  You must have some mixed files in your easyjet livery folder. I have the same EasyJet skin-liveries  and works fine.
Exactly the same problems for me. Occured after latest update with X-Plan 11.35.
Was there a solution found ?
Kind regards,
christoph
61
Some airports lack STAR or are bad.
For example, in LPPT, at least, the GAIOS8A STAR is missing, and in LEVC the MABUX2B STAR is wrong, points are missing. With the SIDs i have not detected problems.
I use the updated airacs, 1909 by Navigraph. With version 3.3R3 used by the old FMGS, these errors do not occur.
Another very important problem for the realism of the simulation is the lack of being able to perform DME arcs.
Sorry for my English.
Can any body tell me why my autopilot dosnt work?
Have a look at my video:
https://youtu.be/DB367pd90Gw
Private video can't see.
64
You should be able to see it now. Thanks
1.You put throttle lever to the Thr Lvr position instead of Thr Clb position.
2.Just after you get AP disengage - you may open log.txt file to read why this happen at last string of log.
First I can tell you that I'cant see all detail on screen. But I'll try to resume what I see.
1. You put flight plan in computer, then you select appropriate SID. You must press all buttons in in performance tab not only speed and flex . But then you manually input some waypoints -why?.
2. When you takeoff you flight to first waypoint with NAV button on,  better put on ARC you could better see the way to waypoint. Then I did not see if you reach the first waypoint - it is wery precise.
3. Then first put your throttle on LVL CLB as you see blinking on  bellow FLEX- verry little back throttle move , and then engange autopilot.
4. If you see that you not properly reach the waypoint and you are not in course you can press DIR button and choose first point on list to go direct to.
5. You set to THR LVR and then you lost your speed an Autopilot disengange.
6. In DATA display you must set knob to PPOS and not STS that you have.
This is what I can see. Maybe you can buy copilot for A320 that will help you to fly.
I'll daily fly with A320 with copilot without any problem all over the world.
Have a nice flying.
67
CORRECTION:
On new test flights the LPPT STAR GAIOS8A if it appears in the FMGS, it was possible that the other time was my mistake.
In LEVC, the STAR MABUX2B is still missing a point, URIAS.
68
Some problems here ... after the aircraft is activated, the popup window ask to me to reload the plane. I do it, but immediately the monitor turns all black. I hear the sound of the engines (even if the plane is Cold and Dark) I can use the Xplane 11 option bar, but the plane is unusable ... any solution? If I load another aircraft in the same session all works perfectly.
69 (edited by laohu314 2019-09-06 18:39:04)
For anyone to help we need at least a log.txt
70 (edited by TKurzweg 2019-09-07 07:28:29)
@ Darko24: Thanks for your help...but it does not work! Fresh installation of JAR 320 without any liveries...after reload this aircraft a short time work without any problems. Copy the EasyJet livery and EUROWINGS livery and I have the problem in all JAR A320 liveries again!
71
Sorry but for me works all your's liveries. I dont know what you have troublle.
Where do you download liveries? I take it from http://simliveries.com/index.php/2017/0 … jet-new-2/
Are you correct put in liveries folder?
http://jardesign.org/forum/img/m/4390/t/p1dk8sjlc21p9qhank2a1ud4192n3.jpg
72
This Version of the a320 does not load. There are loading all Things seen in the loadingscreen but when it Comes to the end x-plane 11 shuts down. so i have to start x-plane 11 new. all other planes working well.
73
Sorry but works fine. I'll just now flight with this version.
Try to fresh install you must have something wrong in instalation.
74 (edited by mahognys 2019-09-13 19:36:03)
EDITED
Lol  I forgot the 2nd page in the init menu :-)
Toc and tod is displayed properly now.
But when i chnage the alt with the knob after takeof the tod/toc and crz alt in init disappears ?
Has the procedure for entering a flightplan in the mcdu changed ?
Im not getting any alt /speed inside the flightplan page ?
Also there is no TOD displayed anylonger either in flightplan page or on the nav display.
What am I missing here ?
Best regards Thomas
Hello!!! What is going on here? https://i.imgur.com/vsdkYBf.jpg  I write about the night textures of MCDU!!!
