Topic: XP11.35 JD330 v.3.2 r4
This is next public version of a330 for X-Plane 11.
What new:
r1:
+ compatible with XP 11.35
+ some systems migrate from SASL to VA (Visual Avionics)
+ APU system reworked
+ ECAM action system reworked
+ Rudder (normal law) algorithm improved
+ about 20 minor improvements
+ LDG MEMO not show fixed
+ Before takeoff checklist fixed
+ No firetest sound fixed
+ no MW, MC sound fixed
+ FMGS module updated
r2:
+ some minor improvements
r3:
+ new VATSIM xPilot compatible
r4:
+ new macOS Catalina compatible
Download link:
http://jardesign.org/a330/download/inst … 30XP11.zip
Download link to updated Ground Handling plugin to be well-compatible with XP11
http://jardesign.org/gndserv/download/GHDxp11.zip
In the case of wrong voice recognition setup crash on loading stage may happen. Please be ready to contact JAR via skype j.a.romanov to demonstrate how this going and make real fix for this by our crew.
- be sure, that you use X-Plane 11.35
- copy unziped "JD330XP11" folder to ..\X-Plane 10\Aircraft\ folder
(create it if need)
If you want to test how failures system work, you need use DatarefEditor plugin and enter "jd/bugs/" there. You will get small number of datarefs what may generate faults - APU Fire, as example, if you change value from 0 to 1.
Please care about information what you will post here and try to determinate reason if issues happen - sure, he interesting in aircraft test and troubles but want to avoid work with "pilot" issues.
Thank you!!!!
