hi everyone, can anyone tell me how to change the voice of atc on xlife?
JARDesign Group Board → Updates & General Discussion → X-Life ver 4 for X-Plane 11
hey guys, i just want to ask the development of xlife still continue?
i have the latest version and still so many things are broken or missing.
example, if i want to make airport hopping, after i reached the first destination and want to departure again to the next one, xlife dosnt work anymore. if i want to make there a new flightplan xlife still think im at the first departure airport. and even if i fill all the data the complete atc is broken and u dont hear the voice anymore. even if i start a new flight it is still broken, i must everytime restart the whole simulator. without restart complete only the text is showing up, that needs an half hour or something before atc wake up again and makes all annoncements at the same time and dont stop talking for a few minutes.
what also would be nice to have an option to scroll trough the flightplan, only this single line where u must press a button a million times before u reach the end of the plan is in my opinion a little stupid
Dear J.A.Romanov,
I found it very strange that x-life atc instructs pilots to, for example, 'turn right two hundred seventy degres' instead of ' 'turn right 270' (two seven, zero). It seems that x-life atc phraseology does not follow internacional rules.
I also found it very strange that nobody is referring this as an issue. So I am inclined to think that I may have configured x-life in a wrong way.
X-life - a very interesting product which provides a good imersion feeling - might even be better.
Could you help me, please?
Thanks in advance.
I need help with X life. I can't run it without game crashing. Seems to crash randomly mostly but unable to complete a flight. I've got all updated version of the plane and xlife. I've installed bluebell packages as well. Any thoughts?
Good day Team,
Got a Crash on the start of the Application when trying to turn off Traffic. In the log I get the error XL: 64 JARDesign Plugin error: Unsupported protocol.
Log link: https://drive.google.com/file/d/1lb4gg5 … sp=sharing
v.4_250719 (updated build of v.4, need reinstall full plugin, NOT only .xpl files this time)
+ ATC panel "auto-hide" off setting add
+ More than 30 compatible airports add
Please send log.txt & xlife.dmp files to www.support.jardesign.org
Just tried to download the new version but the link is still pointing to the old version ?
BR
Frank K.
I can not update the plugin. Therefore, the old version is downloaded via this link. xlife_v4_010519.zip
Same her. Not able to update to newest version.
Same here. Not able to update to newest version
same here.i think the dev is holding back the update
deleted
Hello!
Where can I download the new version v.4_250719?
Sorry-Sorry-Sorry! Wrong link was..
Please redownload plugin from this link http://www.jardesign.org/x-life/download/xlife.zip
Please not mix with old files.
thank you, for that new link for download, sir.
i like this traffic software, primarily at the airports with xlife.
Bought xlife deluxe in august 2018 at aerosoft.
Do you mean that the automatic hidden function disappeared?
Sorry. Understood, everything works.
Thanks for this info, my friend
What I did wrong ?
X-Life said QNH: 1009 but ASXP said: 1018
What I did wrong ?
look like floor operation inside plugins give different results
ivota wrote:What I did wrong ?
X-Life said QNH: 1009 but ASXP said: 1018look like floor operation inside plugins give different results
ActiveSky for XP create a file METAR.rwx.
Can x-life read that file?
J.A.Romanov wrote:ivota wrote:What I did wrong ?
no, it read realworld data from NOAA servers
Thank you for answer.
