326
Merrobe wrote:
Thanks for this version 4,  Great work !
I bought X-Life Deluxe v4 and Follow me car addon and I use X-Plane ver 11.33.  Everything works perfectly …. except for the Airac cycle witch is 7 years old (1201)!!.
I have a subscription to navigraph for the newest airacs version, I love to it use with my favorite liner (Boing 737-800 Zibo mod) and Simbrief as flight planner.
Question: Is it possible to use a newer Navigraph airac version in X-Life, instead of the default airac 1201, that produce many  waypoints errors and specially on SIDS\STARS witch are often revised.
Thank you in advance
You should replace contents of X-life / navdata folder by the latest AIRACS (same as for GNS430/navdata)
Thank you for this answer.
Navigraph has a published list of compatible addons than you can select and update manually or automatically.  But X-Life is not in that list. How can force Navigraph to see it and update it ?
Thanks for your help
328 (edited by vicyang 2019-05-15 12:18:30)
I can't see SHOW ATC PANEL ,FULL SCREEN.
329
JAR A320,A330 and x-life use updated navdata from GNS430 . On Xplane 11 you have to create a folder "custom data" in which you will create another folder "GNS430" .
With that using Navigrah you can download directly update for GNS430 .
Hello Mr. JAR,
Regarding the update from page 12, the link to the latest version of X-life it's not working, as I clicked on it and it gives me the famous 404 error. I remember I updated the version a while ago, about 1-2 months to v4, and I had another problem after fixing the problem with METAR, and that was as soon as I was clicking the ATIS panel, it started the automatic voice to repeat all over again the ATIS for the whole flight, I have to mention that I was NOT leaving the ATIS panel opened, neither the frequency, but it was still kept saying the weather infos. If you can please give us a new link for the latest update, as I want to see if now it's working, because I have deluxe version and it's awful without the weather.
Thank you !
331
ionut97suciu@gmail.com wrote:
Hello Mr. JAR,
Thank you !
Hmm.. please contact me skype j.a.romanov directly - we will test URL reading on your side to understand what we can do.
332
How can I know which version of this plugin do I have? Just is has a lot of crashes and I don't know should I update it or not.
333
check your log.txt
334
same here getting error 404.dont have skype.
thanku
335 (edited by F1le 2019-05-21 07:59:27)
Anybody has idea why xLife doesn't show ATC button despite launching "real life" on the airport, but I just can't enter this ATC box?
This "Show ATC panel" does not exist on my screen on 737 zibo?
Saying other words, have same problem, I can't see "SHOW ATC PANEL", despite the rest seems to work
336 (edited by diaslemuel 2019-05-26 14:40:31)
http://jardesign.org/forum/img/m/8648/t/p1dbq9bg8irc510ur1h0cu7pqvj3.jpgI am facing this issue where the planes are not aligned to the gates or on the taxi way or runway
337
Taxiroute network was created for some exact scenery. If you use another scenery this issue may happen. Plugin have MAP in menu where you can check what scenery was used to create taxiroute.
338
JAR what to do if ATC icon doesn't apprear???? Life is working, planes are running, just can't get to ATC?
339
Please be sure what you activate plugin with your serial "Deluxe" key. Next - use X-Plane Menu->Plugins->X-Life to call ATC window.
340 (edited by F1le 2019-05-28 12:51:45)
Ah, so ATC is in payable version?
Works fine. ATC works in payable version. I was all the time trying to test how ATC works but it turned out it appears in payable, so all clear right now.
341
Hi to everyone!
Is development of x-life dead or still alive? Many CTDs, but without feedback. It seems it´s not compatible to XP 11.34.
Do you have any answers or info?
342
Wonder, Many CTDs with the latest update, it looks like it is not compatible with XP 11.34. Mostly everytime xlifs make  XP crash. then at beginning, next time when I try to plan a route.
343 (edited by artox67 2019-06-04 20:12:07)
Same here. Since update to XPlane 11.34 I get a CTD every flight earlier or later but it comes.
Windows error the crash was caused by the win.xpl data. Log in Xplane doesn't state anything else.
P.S. Without ATC using there is no crash.
344
So, for whom who get CTD on 11.34
1. Please open Nvidia Control Panel and check Off Multithreaded optimisation there.
2. Please update win.xpl file (linked) inside your X-Life folder.
3. Please inform me about result.
345 (edited by SirOTheOne 2019-06-04 18:13:13)
Hi Jar!
i am NOT on windows. i am on a mac os. new win.xpl does not on work Mac OS ,-)
346
Hi Jar!
Attached for MAC
347
Hi Jar!
Attached for MAC
Thanks !!!
348 (edited by SirOTheOne 2019-06-05 18:42:53)
Hi Jar,
last two flights with new max.xpl. 1st flight without X-Life (same route, same weather, same aircraft, same plugins) without any issues. 2nd flight with x-life (config as before) CTD, see log. new mac.xpl changes nothing.
unable to upload log.txt upload images from first and last page of log.txt. Did you change the forum?
edit: something is wrong with your forum settings, can´t see uploaded images and can´t upload any file !!
349
http://jardesign.org/forum/img/m/2147/t/p1dckf9s5cc4r1egl1ogi1d3021n3.png
350
http://jardesign.org/forum/img/m/2147/t/p1dckfb0bo1ca71cvt1oenkqt1bm13.png
