Re: [actual for XP11] GHDeluxe v.4
Did a test using just a single monitor. The widget worked and displayed properly and I was able to add contur image.
Returning to multi-monitor and same result large black square. I assume the plugin doesn't know how to place the widget content at this location or something.
The equipment seems to run really slow when using the widget over the control panel.
Maybe support can comment on multi-monitor support. For now the control panel continues to work as before and now I can have a hotkey to bring up this panel. Thank you for this.
