claytonfreitas360 wrote:Hello! I am reporting a bug in the MCDU the moment I delete the discontinuity of the route is not possible. Does anyone have this problem?
Some Discontinuities cannot be deleted by default (a feature, not a bug). Notably any disco after a "MANUAL" entry generated by the FMGS, can only be deleted after the "MANUAL" entry is deleted. Furthermore, discos inserted by the FMGS at no-SID departures also cannot be deleted. Lastly, discontinuities are not a catastrophe. Simply fly the FP to the disco, then do a DIR TO, or fly "vectors" to the next valid waypoint in the FP or whatever ATC tell you to do. If you don't have ATC then you decide what to do.
