Topic: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
If you update simulator from 11.26 to 11.30, you NEED update aircraft. Update is freeware for "JARDesign a320 for X-Plane 11" users.
FEATURES:
+ X-Plane 11.30 compatible
+ a lot of interior improvements
+ some exterior improvements
+ little system improvements
+ CoPilot plugin* compatible (http://jardesign.org/forum/viewtopic.php?id=11396)
* - separate payware product, on beta-test stage now
PLEASE NOTE:
++ If you have cockpit textures in your custom livery folder - need to delete them.
++ To increasing FCU (autopilot area) display and FCU integrated lights brightnesses you should use two handles just below FCU or above engine display (EWD)
Download link: http://jardesign.org/a320/download/inst … 11_333.zip
- be sure, that you use X-Plane 11.26-11.30
- enter your serial key (Regcode for X-Plane 11 version of JARDesign a320), click NEXT and after a successful activation reopen aircraft via X-Plane menu
- please visit www.simliveries.com to get 130+ free liveries
UPDATE YOU NAV DATA WITH FRESH CYCLE (if need)
- “JARDesign a320/330 Native format”
and put new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
You may switch default/custom installed navdata via MCDU.
Default cycle (Aerosoft, old) always included to _navdata folder.
Thank you!!!!
