Hi All,
After long time not using xlife i installed xlife v4 again. I test it together with JD320 latest release.
My config: windows 10, xp 11.33 (no beta), JD320 v3.3, xlife v4
Navdata updated to airac 0219
Couple things i run into
- when everything setup in a320 i try to import fms into xlife. This is not working, nothing happens and the route stays empty. Try it again and xplane crashes.
- Because i use simbrief, i try to copy the route with sid and stars. This is not accepted in xlife
- I created a txt file with the route (EHBK SID OSGOS DCT LMA STAR EDLV). This is accepted but without sid and stars. Don’t how that works or why sid and stars are not recognized by xlife, for example LMA1W or OSGO1B
- After everything done manually, i try to send my flightplan to ATC, again xplane crashes. (I saved the logs, if needed)
Are there any things i have to repair or install additionally to get it stable?
I have run a flight with only xlife but without atc and another airplane, it keeps running without a problem
Thanks for any support or pointing in the right direction!
Andrew
