126
Re: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
Very minor issues was fixed. No changes for CoPilot. If your r2 is stable - update not need.
Just finished flight with new v3.3r3 with X-Life and Co-pilot. Needless to say it was
one of the most satisfying experiences ever in X-Plane.
Congratulations!
This is  a w e s o m e !
128
Congratulations!
I completely agree with the above written.
I did 3 short flights with all the procedures with co-pilot and the use of X-life and all together worked perfectly.
is there a changelog available for r1, r2 and r3?
130
Awesome!
Thank you JAR Team!
I've installed this new version but I can't find the forlder for custom liveries. How to do that ?
Folder "liveries" is here
133
Dear JAR Team,
Thanks for the update to R3, but upon flying at night I cannot see Strobe lights on either wing from the window view. If I go outside the aircraft beyond the window limits they show up but from within interior looking outside...no strobes. I have uploaded a couple of pictures to show...left picture is outside the window but still within Cabin, while 2nd picture is inside. If you notice the vertical dividing line within the 2nd pictures shows the border between both.  Please advise if this is being looked at for a fix. Aside from that no issues and great update. Thank you so very much. -Cheksix.
134
Thanks dron420 but i can't see the Liveries folder you are talking about in you last post.
135 (edited by gigabenga 2019-01-27 15:13:50)
The Autopilot and qnh is to dark no brightness.
vers. 3.3 xplane 11.31
any Solution?
They other display´s no Problem
edit. Solutions found
136
http://jardesign.org/forum/img/m/6428/t/p1d27t3br6pec5fm1n5khgh1dt93.jpg
137
http://jardesign.org/forum/img/m/3263/t/p1d29lu66hgdpslnv4211gp1cik3.png
138
In the last version, the speedbrakes are deployed way too fast!
Video: https://youtu.be/YTF_NNi_C_s
(Thank you for the update, love all the new changes/adds!!!!)
139
I just noticed that pressing the APU Master Button also activates the APU Start Button simultaneously. That should not happen. Is that a problem with my installation or is this a known bug?
i preferred the dark cockpit textures in the previous version - hope they make a come back!
I cant delete some discontinuities in mcdu... whats wrong?
142
That is because some discos cannot be deleted, like if you don't enter a SID there will be a disco before the first route waypoint that cannot be deleted. You have to enter a Direct To the first waypoint after takeoff.
143
How do you turn down the volume with  JD320-V3 3R3?   The Loudspeaker control does nothing, neither does the sound 3D plugin.  I need control of the volume when talking to ATC
144
Hi Sir in to MCDU menu
145
Thanks, I'll have a look.
146 (edited by dron420 2019-02-10 12:51:56)
Loudspeaker control and local controllers on audio panel are working, but  need to take in account that X-Plane cant change volume when some speaking is in use (for example answer from ATC). If you need immediate reaction from volume control just switch to another source (for example COM1->COM2->COM1 or ACTIVE->STB->ACTIVE) and then switch it back (or switch on/off/on specific sound source on audio panel) , and you have new level of volume or wait until end of XP speaking, so new part of speaking will be with your level of volume.
147 (edited by aleplane 2019-02-13 09:43:01)
with the last A320 V3.3 r 3
I have a big problem in reaching cruse level.
It took me almost an hour to reach FL370 with no more than 10tons of fuel
Also when reached the cruise level the plane is unable to go faster than Mach 0.68
I believe there's a problem with engine thrust.
This happens with PW1000G and similarly with CFM engines
Is it possible to tweak the thrust?
-EDIT- following the suggestion to disable Xplane experimental mode, performances seam to get back to normal, taxiing though still require 45%of thrust, not sure this is normal.
148
"Use experimental flight model" is on?
Try to turn it off.
I actually need it on for the Zibo mod.
I'll give it a try turning it off,
Try to turn it off.
150
Good afternoon. Began to experience CoPilot, until not all my words understand. Tell me how can I get an enhanced version? Thank you in advance.
