Re: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
The flaps indicator fix is first fixed posted in Jar Design Facebook Group
https://www.facebook.com/groups/207012966130101/
https://www.facebook.com/groups/2070129 … 482371740/
The flight profile is a setting in MCDU "Show Prof"
X-Life Deluxe
GHD
FMCAR
JD320
102 (edited by calpol3 2019-01-09 17:10:18)
The green route line isn't appearing on the ND for me but the aircraft is following the route I've programmed in.
Using 11.30rc2and v3.3r1.
http://prntscr.com/m509eq
103 (edited by antbur121 2019-01-09 19:02:39)
I'm having a problem with my A32O Version 3.3 R1 on x plane 11 11.30R2. The plane will not fly with correct flight plan. I'm put all the data in correctly to the MCDU. I have the antenna aligned correctly. After take off the plan flights in one direction once auto pilot is set. Even when I choose direct to a Fix or Waypoint it changes the flight path but then just stays at the same heading. If anyone know what I'm doing wrong please help?
http://jardesign.org/forum/img/m/7875/t/p1d0pvt41j1gp116fpo6h1rqubc23.jpg
Full documentation of MCDU Menue settings.
Dear JD team, I (and many other users) don't want to search for any documentation and patches for JD320 on other channels or sites (like Facebook).
I do prefer to get all necessary information in the dedicated support forum for JD320, nowhere else. One stop for all information.
I hope you can understand this. Maybe DOC folder is the best place for this kind of information.
We (users) would like to get full understanding of the MCDU Menu settings purpose in order to use your great product in the proper way.
105 (edited by tanguy317 2019-01-09 21:39:06)
Dear JD Team,
i have still the same problem,
indeed, no engine sound with BSS since the update to this 3.3 r1 version,
i have installed and updated again my JD 320 but no change.
Can you please help me to fix this problem ?
flying with your JD320 without sound is very distasteful..
tanguy317 wrote:
Dear JD Team,
Have you deleted the sound3d in the plugins folder?
107
Hello JAR
What is the diference between JD320 v.3.3rc1 and JD320 v.3.3rc2, a part of having Copilot support?.
Can it be used without that complement?
Do you have any improvement?
According to a fellow member of the forum, he said that you were working on an improved version to increase the FPS in modest PCs.
I'm very happy with the version JD320 v.3.3rc1, but if it could be improved, it would be great
good job Team JAR
108 (edited by juanra100 2019-01-10 19:06:06)
dron420 wrote:
dkuhlmeier wrote:
stateless_01 wrote:
So I am the only one with FPS drop after the update?
No, you are not the only one.
I wrote about the same problem 2 days ago.
I still waiting for an answer.
You shouldn't have any FPS drop with new version, but we are working with special optimized update which has target to increase FPS, especially for low spec PCs (the rest as well of course).
I put the post of the partner of the forum that wrote this ; )
109 (edited by stuarth 2019-01-12 18:26:25)
JarDesign A320 3.3.r1 and XP11.30
I use CH Throttles, and have found that the flaps axis doesn't completely perform a complete flaps up without necesitating  clicking on the flaps handle. Any suggestions? I have recalibrated in XP11 but no joy.
Also the XP "Toggle TrackIR" doesn't work. Not sure if this is related to the JDA320 or XP11.30?
110
For VR use, I find the reflections in the windscreen very distracting. Especially at night-time. It looks you are diving.
111
I'm having issues with the QNH synching between that shown on the PFD and that in the QNH window. Some of the numbers in the PFD are missed eg it jumps from 1020 to 1022. Anyone else having this problem? Do I need to re-load? Any suggestions appreciated. Couple of examples attached.
http://jardesign.org/forum/img/m/7815/t/p1d1gcbcnc1ke3asns78kbg5k83.jpg]
sorry -example:)
113
Yes, I have been having this issue for years. Hopefully it'll get fixed at some point.
114
I notice that the text on the FMC scratchpad is slightly cut off at the bottom in the new version. Is that user-fixable somehow within the various files? Or could the appropriate replacement file be uploaded here perhaps by JD?
115 (edited by sidiclei 2019-01-20 15:45:43)
http://jardesign.org/forum/img/m/6561/t/p1d1luoplp6361npj15at1elruqs3.jpg
Hello there,
Is anybody having this problem in the cockpit of the A320? Under the pedals I see green like the texture doesn't look right.
116
I read that there is an update for $19.95  from XPlane 10 to 11.  (v 2.7 to 3.x) if purchased before Nov 2017. Where can I find this?
117
Read first page
118
I don't want to be annoying, and this has probably been said before, but the fire tests don't work. I'm sure it's not a big deal to correct. It is just that pressing the buttons is not persistent and therefore, the alarm doesn't actually ring. That goes for all fire test APU and Engines
119
Works fine for me. All test works. I don know but I have instaled BSS JAR A320 V4 sounds.
120
To increasing FCU (autopilot area) display and FCU integrated lights brightnesses you should use two handles just below FCU or above engine display (EWD)
That method don't work......my FCU auto pilot area still dark!
121 (edited by laohu314 2019-01-22 15:04:22)
OK, so this is interesting. I have a .lua script where I created a switch for the fire test datarefs. That prevented the fire test from working. I have removed the "offending" definitions and now the fire tests work as expected. Sorry for my confusion.
122
Please update to version 3.3r3
Download link:
http://jardesign.org/a320/download/inst … 11_333.zip
Hallo, exciting ! Can you specify the most important changes?
124
Co-Pilot 2 files also changes?
125 (edited by martinlest 2019-01-23 16:20:22)
It's all looking pretty nice now - thanks for the updates. Just a reminder for the next update though - I have 3.3r3 and the text on my CDUs' scratchpads is still cut off at the bottom...
