Re: CoPilot Beta-tests
Thank you.
I must be honest I have not had any major issues with the previous version.
My accent seems to challenge the Microsoft Speech Recognition engine but Sandy performed very well thus far
JARDesign Group Board → CoPilot for JD320 → CoPilot Beta-tests
Thank you.
I'm going through the new scripts. I'll comment on findings
In Cockpit Preparation Procedures there is this:
pos:lookovhd
if:sim/cockpit/switches/fasten_seat_belts==0
pos:seatbelts
drf:sim/cockpit/switches/fasten_seat_belts=1
saywait:Sings selector, on!
endif:
I suggest to change to:
pos:lookovhd
pos:seatbelts
saywait:Seat belt signs, on!
endif:
In the After Start Checklist the is this:
#########################Trim######################
pos:chlecam
pos:flctrlpage
saywait:Pitch trim
drf:sim/custom/xap/disp/sys/mode=4
pos:chlecam
if:sim/custom/xap/mcdu/ths_angle==0
and:sim/custom/xap/reload/cg<28If
saywait:Pitch trim is not set at M C D U. Before start checklist is not completed
pos:chltake
drf:jd/fo/_planshet=0
pos:rest02
break:
endif:
and:sim/custom/xap/reload/cg>29
pos:rest02
break:
endif:
Should it be:
pos:chlecam
pos:flctrlpage
saywait:Pitch trim
pos:chlecam
pos:chltake
pos:rest02
break:
endif:
pos:rest02
break:
endif:
Noticed that when I change Co-pilot to w (female) the voice and the positions change but the body doesn't and so all the positions turn out wrong. Otherwise, the co-pilot is pretty perfect. everything else is cosmetic and personal preference. I have made some personal changes in language and sequence of events in the procedures which I will post after more testing.
But again, THE CO-PILOT IS GENIUS!
Sorry, but I am really excited about this.
pos:chlecam
pos:flctrlpage
saywait:Pitch trim
pos:chlecamif:sim/custom/xap/mcdu/ths_angle==0
pos:chltake
pos:rest02
break:
endif:if:sim/custom/xap/mcdu/ths_angle==0
pos:rest02
break:
endif:Should it be:
pos:chlecam
pos:flctrlpage
saywait:Pitch trim
pos:chltake
pos:rest02
break:
pos:rest02
break:
endif:
Thanks, we'll fix it, it's a typo.
Flying with new version. Nice flying, everything works fine except in any procedures transponder is still no set on. I suggested in previous sightings, that include in some procedures at least in Before take off procedures, commands what is the included in Before take off checklist:
pos:chlped
if:sim/custom/xap/atc/mode_sel!=2
pos:atc on
drf:sim/custom/xap/atc/mode_sel=2
saywait: Transponder on
endif:
In sop folder they are two the same procedures Befor Pushback or Start.txt and Before Pushback or Start.txt, with the same text, why?
Trying the latest version now... Sandy got stuck on the Flight Control Check... Repeating the words Flight Control Check over and over and over ...................
I had to abort him completely now
I have that also some times. A command is repeated over and over. Even commanding "abort" doesn't always work in such a situation. Is there a debug mode one can turn on so that we can report some relevant data when that happens?
Hi JAR Team,
Thanks for your amazing work done so far!
It works well, no blocking issues (except the bug raised by @sKYMATIX later, encountered only 1 time after 5 flights).
Regarding the UI, I know this is a beta and that's absolutely not the priority, but I've found some little typos into different settings (common with a330 copilot plugin):
1. "Preliminary Cockpit Preparation" Procedure, there are missing "p" in the Cockpit words in:
copilot_main\custom\commands\Procedures\00_PrelCockPrep.txt: input:Preliminary Cockit Preparation
copilot_main\custom\execute\sop\PrCocPrep.txt:
> waitsay:Preliminary Cockit Preparation Procedures
> say:Preliminary Cockit Preparation Procedures complete
2. "Before Start Procedures", there are missing "e" at the end of Before words:
copilot_main\custom\commands\Procedures\02_BeforPushbackOrStart.txt:
> input:Befor start procedures
> execute:sop/Befor Pushback or Start << here I guess this is the call of the sop file, there are 2 files, one with a Before, one without "e" in the folder
copilot_main\custom\execute\sop\Befor(e) Pushback or Start.txt:
> saywait:Befor Start Procedure
> saywait:Befor Start Procedure completed
Also, I've found "Standart" at any places, I belive it is "Standard" instead. (I'm not an English native speaker so maybe I'm wrong...).
Hope this will help you for the final version
Could we expect a kind of dialog box to modify the values from the settings.txt file (I mean, the Co-pilot/pilot names and sign) ?
Thanks & Regards.
Hi JAR Team,
> say:Preliminary Cockit Preparation Procedures complete2. "Before Start Procedures", there are missing "e" at the end of Before words:
> execute:sop/Befor Pushback or Start << here I guess this is the call of the sop file, there are 2 files, one with a Before, one without "e" in the foldercopilot_main\custom\execute\sop\Befor(e) Pushback or Start.txt:
> saywait:Befor Start Procedure completedAlso, I've found "Standart" at any places, I belive it is "Standard" instead. (I'm not an English native speaker so maybe I'm wrong...).
Thanks & Regards.
Thank you! fix it.
sKYMATIX wrote:Trying the latest version now... Sandy got stuck on the Flight Control Check... Repeating the words Flight Control Check over and over and over ...................
Thank you! I think not, but we will try to catch this error
Please update JD320 to version 3.3r3:
http://jardesign.org/a320/download/inst … 11_333.zip
Thank you will do immediately
So, beta-test period is over. I want to say THANK YOU for all beta-testers for Opinions, Notes, Bug-reports, Files, Scripts and so on. Sure, you may use your serial keys for JD320 CoPilot future activations.
As for now - we just start ability to get serial key as payware product with Low Cost price 9.95 USD (w/o VAT)
Please redownload and reinstall CoPilot plugin to get updated version (some position and text was improved/fixed, endless saying bug fixed).
