Re: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
SilvioRodrigues wrote:The pedestal lights are not working for me.
More details, please
To be more specific are the flood lights.
JARDesign Group Board → Download, Updates → JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
Great work Jar team on this update. I just ask that if you could please keep the way you have the copilot interaction now but when you update to the copilot plugin, please make that an optional plugin. I'd rather have the copilot the way you always had it but then I'm doing all the work but with guidance. I hope this would be same with the A330. Thanks again for great planes.
330 and 320 CP are different in this case. 330 CP is freeware, 320 CP will not. Sure, 320 CP will have old copilot voices "from the box". If you dont like install CoPilot, 330 version 3.0 may be used, cause 3.0 also work well with 11.30 and have old-style "from the box" copilot voices. In this case I am not see reason for JD330 update.
Son_of_Jorel wrote:Great work Jar team on this update. I just ask that if you could please keep the way you have the copilot interaction now but when you update to the copilot plugin, please make that an optional plugin. I'd rather have the copilot the way you always had it but then I'm doing all the work but with guidance. I hope this would be same with the A330. Thanks again for great planes.
Okay, thanks Eugeny.
dron420 wrote:SilvioRodrigues wrote:The pedestal lights are not working for me.
Why you are mixing textures? If you have cockpit textures in your custom livery folder - need to delete them.
FLOOD LT not working for me 11.26 R2
I have some suggestions for VR.
For rotating FCU knobs it would be nice to have the native
"wrist move" like the standard 737 that comes with X-Plane 11
SilvioRodrigues wrote:dron420 wrote:More details, please
I did not mix texture, I did a completely clean installation.
I am also using 11.26 R2 and the LT flood does not work.
dron420 wrote:SilvioRodrigues wrote:To be more specific are the flood lights.
If you have custom livery it can contain old cockpit textures.
We will check overhead flood/
We are working with VR to make it more comfortable
SilvioRodrigues wrote:dron420 wrote:Why you are mixing textures? If you have cockpit textures in your custom livery folder - need to delete them.
you're right, this texture is livery.
I just downloaded 3.3r1 for Mac OS and used it with X-plane 11.30r1. After a few minuets of twiddling around it fired up for me, pulled into the skies over over Munich and took me to an auto landing at Paris Orly. All good. If the next patch works as well as this one seems to it will be a keeper.
Hello!
Circles on screen, resolved.
Now, the tilt value of the weather radar is missing (weather is on).
Manipulating the radio with the mouse wheel, sets the standby radio values manipulated to 0.
Rose ARC NAV (zoom), 2 clicks left at 10 (5?) and not change to 320 (max. 160).
Thanks 4 all.
Best regards.
hades.esp72 wrote:Goog day.
- XP10.26.
- Clean installation.
- BBS Sounds.Ready for taxi status:
Ready to land status:
Thanks 4 all
Best RegardsI think you are referring to the multiple "white circles" on the upper ECAM display? I noticed that as well. Other than that, my first flight was the most stable one I can recall in a while, barring some weird issues with STARs into my arrival airport.
Does anyone have the integration with the Avitab plugin?
plugin crashing very frequently!
Dear Jardesign team,
between the last used version 3.30 r3 and the current download version I have fps drop of aroung 7-10 fps, all the time, in all situations.
So I have to go back to the older version to be able to use it. ?
Still the problem with the AP display/screen, it stays dark in every situation.
Tried everything i could imagine but no change.
Had to go back to the older version of the A320 ![]()
Hope this will be fixed soon.
Had to go back to the older version of the A320Hope this will be fixed soon.
Hi Sir you must only turn button light down display of Altitude AP
etc ecc
HELLO
can't reactivate my a320. can you help me?
HELLO
please www.support.jardesign.org with your serial key
Calibra44 wrote:Still the problem with the AP display/screen, it stays dark in every situation.
etc ecc
Thank you Sir! It works!
My misstake was a bad ankle of view so the button never appeared "active".
Still a lot to learn, thanks again!
Thanks for the small fix for the upper ECAM and DISCO delete. One question, has anyone requested to implement the "zoom to current fix" feature on the MCDU when you hit the F-PLN key? Basically, when you finish building the route, you are way down the waypoint list. Hitting "F-PLN" whenever you are on the F-PLN page should take you back to the current/next fix in the flight plan. Any consideration for this?
Aaron
domined39aniello wrote:Calibra44 wrote:Still the problem with the AP display/screen, it stays dark in every situation.
etc eccThank you Sir! It works!
My misstake was a bad ankle of view so the button never appeared "active".Still a lot to learn, thanks again!
Merry Christmas
Sorry, this may have been mentioned somewhere already. The VR is awesome! However, how do I control the stick? (Yoke?)
Amazing work with this update jar, the enhancements with the cabin are great, and in VR this works wonders. One question though, I've been struggling to figure out how to adjust the cabin lighting, is it even possible?
Great job, excellent aircraft. You can add a tablet like in FF ![]()
