This aircraft needs work, as soon as I try to edit a flight plan in the MCDU everything just locks up, it's just useless. A330 is fine though.
Let me dream a little about a new JD320
- more stability than V3 .. i think this can be fixed with remove of SASL like the A330
- remove of the endless clicking sound when pressing r/l arrow keys in FMC where they are not valid
- Usage of Xp11 navdata, i dont like it to have x positions with different navdata .. its not so good when different part of sim uses different data (Aircraft, traffic/atc addin, external map app, ....)
- a jacket for the FO, i like it cold in my cockpit big_smile
- airport nav map on nd .. i have seen this on a real A321 video .. i think JAR has the base technique, because of FMCar
- all rotation knobs rotate right for mouse wheel up and rotate left for down .. current version is not consistent
- move switches with mouse wheel too (esp. multi position switches)
- more realistic speeds/flight physic .. i dont think that every managed decent needs Speedbrakes "we need more drag sir"
- moveable MCDU, undockable, to second screen
- performance calculator (V Speeds, CG, ZFGW, runway length, runway condition, to shift, ...)
- default x-camera preset
- both cockpit seats filled with people for outside view .. best selectable female/male
- transparent schematic throttle display (when moving throttle) as overlay on main screen to better hit clb and flex
- better handling of following flights without reload aircraft
- better handling of in flight changes of destination
- better resume of f-pln navigation after manual HDG or DCT
- handling of TOGA, fly go around part of STAR, return to F-PLN after TOGA
