I am trying to update my A330 with my serial key but just found out that I need a new one...what can I do to get a new one please?
Kind regards
Martial
JARDesign Group Board → Downloads, Updates. → XP11 JD330 v.3 r1,r2,r3,r4,r5
Kind regards
Martial
Kind regards
Martial
Interesting, how did you find out that you need a new serial key?
martialblaizot wrote:Hello,
Kind regards
Martial
Hi Ilankrt
I told that because Martialblaizot has only the Xp 10 version and he wants to use this aircraft on Xp 11 …
And this is what every body has done , even yourself …
Hi. When will the X-Envira be able to work normally with weather radars of aircraft?I for all time of flights on А320 330 JAR, from did not observe light on a radar,Will this be realized?
Can you fix the engine heat shimmer so that it is attached to the engines.
There is a gap if you look from the sides.
thx!
DEAR GUYS
I cant seem to be able to operate both the flaps and the landing gear levers with the mouse
is that normal or it is just me having the issue.?
regards
We still wait API to make possible X-Enviro weather drawing. Cant do any without this.
There is a gap if you look from the sides.thx!
May I look at screenshot, please?
DEAR GUYS
is that normal or it is just me having the issue.?regards
This is normal for JD330, Copilot check your command before execute it.
270 Weight Ropes and Ocher Desert
It's only one time before Nike released the Premium Edition 270 Edition, now available to selected retailers.If we look so closely, the combination of the color orchestration of ocher. As you can see, this pattern has a layer of perforated skin while the skin and the skin of the pearl falls somewhere. Complete the view of the chain.
Keep scrolling to see more photos of Thong and the Orero Desert to give you a better idea. Now they reach some Nike sports retailers like Rock City Kicks. The retail price is set at $ 170.Nike Mercurial Vapor Flyknit Ultra Play Fire Zapatos ;
Air Jordan 4 Military Azul;
Barato Air Jordan 14 Desert Sand;
Air VaporMax Inneva Zapatillas;
Nike M2K Tekno Zapatillas;
Venta Nike Cortez Cinco De Mayo;
Adidas Terrex Trailmaker Gtx Zapatillas;
Nike Air Max 1 Ultra Moire iridescent Zapatillas;Cheap Nike Kobe 1 Protro MPLS;
Cheap Nike KD 11 EYBL AO2604-600 ;
Sale Nike React Element 87 AQ1090-100;
Cheap Air Foamposite One "stealth";
Air Jordan 11 "dirty Snakes" Varsity;
Air Jordan 2 "alternate 87";
Cheap Adidas Alphabounce Space Dye Sneakers;
Discount Adidas Eqt Support Rf Primeknit Sneakers;
Buy Adidas Samba Sock Primeknit Sneakers;
A Buon Mercato Polo Ralph Lauren Christy Turchese;
Nuovo Sconto Polo Ralph Lauren Harper;
Air Vapormax Flyknit Cdg 924501-002 Scarpe;
Negozio On-line Polo Ralph Lauren Pyjamas;
Polo Ralph Lauren Tompkins Denim;
Polo Ralph Lauren Tracksuit Bottoms Mottled;
Polo Ralph Lauren Traveler Multicoloured;
Vente Polo Ralph Lauren Varick Denim;
Polo Ralph Lauren Coupe-vent;
Adidas Y3 Yohji Run Bb4865 Chaussures;
Adidas Yeezy 500 Desert Rat Super Moon Db2966 Chaussures;
Vente Yeezy Powerphase Cg6420 Baskets;
Bait X Adidas Eqt Support 93/16 Cm7874 Chaussures;
I do not believe that this platform is used by fashion companies! ....simply unbelievable. I hope JAR DESIGN will refuse this kind of misbehaviour.
Hi everybody,
I am still running the A330 and A320 in XPlane 10. I saw, that updates for these two planes were only available if you use xplane 11. Will there be any updates on xplane 10 in future?
Thanks in advance for your answers. Nick
I don’t think so...
Does BSS soundpack works with latest release (v3r5) ?
Yes, I own the main RR package and the two GE and PW expansions. For now I'm using the Trent and it works perfectly. Here a little video with the sounds of BSS:
https://www.youtube.com/watch?v=4o-0eLEYKbQ
Hello JAR Team,
Great to see the 3.0 update to the A330. I've removed my old installation and copied in the new A330 folder. My "Plate.txt" file shows JD330 V3.0R5. When I load the airplane, I was asked to activate which completed with success. Next, I am receiving SASL errors:
ERROR: a33o system (SASL) plugin not activated
I see the plugin is active in my XP plugin list. and in the LOG.TXT file I see the following below. Can you please provide some insight?
Thanks - Aaron
[SASL] Path to panel: D:\X-Plane 11\Aircraft\JD330XP11\aircraft.key
[SASL] Loading avionics...
[SASL INFO] loading panel
[SASL ERROR] P11\aircraft.key: cannot load malformed bytecode
[SASL ERROR] can't load component panel
[SASL ERROR] Error loading panel D:\X-Plane 11\Aircraft\JD330XP11\aircraft.key
G64: 268.445: Livery Changed:(American Airlines (N291AY)) Folder:(Aircraft/JD330XP11/liveries/American Airlines (N291AY)/)
0:04:16.078 I/FLT: Init dat_p0 type:loc_specify_lle lat:33.939590 lon:-118.406498 ele(ft):115.783062 psi:343.698059 spd(kts):0.000968
0:04:33.790 I/OVR: Reading VR conf file: Aircraft/JD330XP11/a330_vrconfig.txt
0:04:33.790 W/VRCONFIG: Could not find vr config file: Aircraft/JD330XP11/a330_vrconfig.txt
0:04:33.790 W/VRCONFIG: VR Config data file for Aircraft/JD330XP11/a330_vrconfig.txt is not valid!
0:04:33.790 W/MANIPS: Could not find vr config file: Aircraft/JD330XP11/a330_vrconfig.txt
0:04:33.790 W/MANIPS: VR Manips file for Aircraft/JD330XP11/a330_vrconfig.txt is not valid!
0:04:33.790 D/STM: Transitioning from state state_NormalLoading to state_Normal
SoundSetPath=D:\X-Plane 11\Aircraft\JD330XP11\plugins\sound3d\
VolumePath=D:\X-Plane 11\Aircraft\JD330XP11\plugins\sound3d\volume.txt
I can't get the radios in this thing to work on PE.
I can start but in the middle of the flight crashes the game.
Now the question is what can I do?
https://workupload.com/file/CnUWU7v8
https://workupload.com/file/mMDAxrSt]
hi @jardesign group i just Updated the airplane to the latest version R5 and theres is a problem when you go to the FMC / settings /rain effects on.. when i turn the rain effects on the windshield go purple with little squares if I turn rain effects off the windshield just work fine
i have a strange issue and i'm not sure what is causing it. Usually it get quite good frame rates when i'm flying the JAR A330: Around 40 fps on the ground and up 60-70 fps while flying (depending on weather and other stuff).
But when i'm doing long haul flights sometimes the frame rate will drop down to 20 or even below (18 or something) and it will stay like this. Until i touch down at the arrival airport when suddenly the fps will go back to ~40.
Does anyone have an idea what might cause this issue? It happened to me today on an 11 hour flight from LFPG to ZGGG. I had a similar issue some weeks ago when going the other way from ZSPD to EDDF (if i remember correctly).
Strangely i never had issues when going over the Atlantic ocean (for example LFPG to CYYZ some days ago => no issues).
I will check if this happens with other planes too, but i don't remember seeing something like this in other planes.
Any ideas???
P.S.: Otherwise I really love flying the A330! ![]()
I downloaded the JD330_v3 file now, I did not find the _NavData folder here .
it is located at : "aircraft"/plugins/fmgs/navdata ….
I just love the floating MCDU (FMGS - FMS). A silly question maybe:
Is there a way to enlarge (resize) the MCDU? Does it accept keyboard strokes or do I still need to push the buttons?
Please let me know.
Theo.
*** pls disregard ***Just updated to newest version V3r5. Installed as new with XP11.26. Loading causes CTD.
So sad. On MacOS latest version. Other a/c work well. *** got this bird working ***
Can anyone help me? Im having problem with my a330.
Problem:
- Rudder is Flickering left to right when flying but not on the ground.
- Wind direction and TAS number are flickering
- EGT FF kg/h are also flickering.
- When descending from high altitude, air speed is also flickering
Jar A330 v3r5
