shanemontoya wrote:v3r4
1. ZBAA RWY36R Go-Around route - why the aircraft draws such awkward turn like that?
2. Missing runway symbol ("="symbol)
3. Alt constraints below FL100 shouldn't show "FL" - 3940ft shouldn't be FL3940 right?
4. From cold and dark, why the RAT is deployed?
5. After takeoff, the ND went out however the zoom function of the ND is still available.
6. Forget one thing during engine start - before clicking the ENG1, the EPR indication in the EWD rotates violently - I just used keyboard for my engine input, no hardware throttle control.
7. F-PLN in selected mode - the curved f-pln is still solid, but the rest of the straight lines are dashed.
I am using the latest stable version of XP11.
Please fix them in the next version.You should begin with a Cessna 172. It is the best way to learn how to fly and use instruments correctly......
ha? a simmer calls a RL airline guy to learn 172 first? all right you win.
As a winner, please explain why the ND shows FLXXXX when the ALT is below FL100; or why the f-pln drawing algorithm is unable to handle some leg drawing. Regarding the drawing, if I remember correctly, dating back in 2015 JAR320 could do perfect curve drawing for some interesting approach like the DME ARC in ROAH.
